2006 GEN3 Smart Sway bar
Searching for a good or even better, NOS, complete sway bar for my 2006 PW.
Thanks!
Thanks!
2006 Dodge Power Wagon 2 door, planed to be used as an overland vehicle with a camper cabin
1972 Plymouth Road Runner 440-GTX, TX9 black with B5 blue interior and original airgrabber hood
Re: 2006 GEN3 Smart Sway bar
If anyone searches one, I bought it here... this guy seems to have more in stock, he put it again online:
https://www.ebay.com/itm/2006-Dodge-Ram ... SwB9Jc3e-w
The new sway bar will have to be programmed to the truck before it will work properly, so don't think it's defective if it doesn't work right out of the box.
Even for an old dinosaur like that?!Retired BLM Rig wrote: ↑Thu May 23, 2019 10:36 amThe new sway bar will have to be programmed to the truck before it will work properly, so don't think it's defective if it doesn't work right out of the box.
??????Retired BLM Rig wrote: ↑Thu May 23, 2019 10:36 amThe new sway bar will have to be programmed to the truck before it will work properly, so don't think it's defective if it doesn't work right out of the box.
RustyPW wrote: ↑Sat May 25, 2019 4:37 pm??????Retired BLM Rig wrote: ↑Thu May 23, 2019 10:36 amThe new sway bar will have to be programmed to the truck before it will work properly, so don't think it's defective if it doesn't work right out of the box.
I know when the dealer put tow mirrors on my truck when I was buying it they had to be programmed too.
When I put tow mirrors on my 08 PW. It was plug and play.olyelr wrote: ↑Mon May 27, 2019 10:40 amRustyPW wrote: ↑Sat May 25, 2019 4:37 pm??????Retired BLM Rig wrote: ↑Thu May 23, 2019 10:36 amThe new sway bar will have to be programmed to the truck before it will work properly, so don't think it's defective if it doesn't work right out of the box.
Any module changed on the CAN needs to be introduced with a handshake. Tow mirrors are not on the CAN in 2008, but for 2016 with memory seats, pedals and mirrors, I can see the BCM needing to be informed of the changes.
Yea, but he’s got a 2006.Retired BLM Rig wrote: ↑Tue May 28, 2019 9:41 amAny module changed on the CAN needs to be introduced with a handshake. Tow mirrors are not on the CAN in 2008, but for 2016 with memory seats, pedals and mirrors, I can see the BCM needing to be informed of the changes.
2006 and newer PW's have the SmartBar tied into the CAN system.
thanks for the hint!
Good to know! I also didn't know that. NO idea if they can do it here, but I hope someone can...
I installed my new smartbar. It was plug and play. It didn't need the hand shake. Plug it in and everything works. My lockers lock up faster now.Retired BLM Rig wrote: ↑Tue May 28, 2019 9:41 amAny module changed on the CAN needs to be introduced with a handshake. Tow mirrors are not on the CAN in 2008, but for 2016 with memory seats, pedals and mirrors, I can see the BCM needing to be informed of the changes.
That's great news! I'm actually glad I was wrong about this one, so you don't have to give anymore money to the stealership.RustyPW wrote: ↑Sat Jun 08, 2019 12:20 pmI installed my new smartbar. It was plug and play. It didn't need the hand shake. Plug it in and everything works. My lockers lock up faster now.Retired BLM Rig wrote: ↑Tue May 28, 2019 9:41 amAny module changed on the CAN needs to be introduced with a handshake. Tow mirrors are not on the CAN in 2008, but for 2016 with memory seats, pedals and mirrors, I can see the BCM needing to be informed of the changes.
