Hi.
I just installed my locker bypass and it worked great. The only problem that I have in two wheel drive when driving with rear locker off I get an intermittent buzzing sound out of the control box. I mounted it under my dash panel per instructions. Is this supposed to happen? Please let me know
Tony Picaso
Bigamehunter007@msn.com
Buzzing noise from control box
Re: Buzzing noise from control box
There is an adjustment for that inside the box. You should have gotten installation instructions with it that shows how to adjust it.
Easy to do, I had to adjust mine also.
Thanks for the reply, I did just that and it worked, no more buzzing.
Glad to see you got it figured out!
