Abel Components Sway Bar Bypass® - $249
Retired BLM Rig products
Post by Retired BLM Rig » Sat Nov 30, 2019 4:01 pm
The Sway Bar Bypass® is a stand-alone system for giving the driver complete control of the disconnecting sway bar, from the comfort of the driver's seat, in any transfer case range, at any speed. It works on all years of Power Wagon and is completely electric (no OBA needed) and comes with everything you need to wire it into your vehicle, without cutting or splicing into any factory harnesses. This system abandons the factory sway bar switches and utilizes its own rocker switch with an indicator light, that shows when the sway bar is disconnected. There will be no flashing lights on the factory switches and the lockers or Locker Bypass will still function like normal. It does not affect the engine or transmission performance.
Purchasing this device puts the driver back in control. It is intended for off-road use only, NEVER DISCONNECT THE SWAY BAR ON THE HIGHWAY! Always practice safe off-roading and use common sense. Purchasing this item means that you take back control of your truck, as well as take on full responsibility for your actions and consequences after you flip the switch.
Send me an email to order this item: AbelComponents@yahoo.com
Abel Components... Putting the driver back in control.
Re: Abel Components Sway Bar Bypass® - $249
Post by olyelr » Sun Dec 01, 2019 10:43 am
Great job, David!!!
Oilbrnr
Post by Oilbrnr » Sun Dec 01, 2019 11:30 am
It works as advertised! Makes my 3 mile off-pavement journey to my house just a tad softer. It was a pleasure working with David.
'16 with '17 FWC
PWJouster
Post by PWJouster » Mon Dec 02, 2019 8:12 am
lol hahahaha
cant believe im about to ditch my EVO Mfg on demand air release for this electric system which serves the same purpose....
Wait, yes I can, its an Abel Components Product helping my Powerwagon become most Abel
bye bye ARB solenoid!!!!!
Post by OffroadTreks » Wed Mar 04, 2020 12:33 pm
THIS IS THE COOLEST THING EVER!!!!!!!!!!!!!
Oilbrnr
Post by Oilbrnr » Wed Mar 04, 2020 3:41 pm
I use mine every day I drive the PW. Pretty much disengaged all the time unless I'm going over 60 or its real windy with the FWC.
'16 with '17 FWC
Idaho RC
Post by Idaho RC » Sun Mar 22, 2020 5:50 pm
I have had my sway bar bypass sitting on a shelf for months waiting for warmer weather to arrive. I finally installed the kit this weekend. The entire kit is super! The directions, the wire length even the switch is just great! Installing the kit was really simple and I couldn’t be more pleased with it!
Thank you for proving such nice improvements. I am really happy with the all of your kits!
