FOR SALE 2009 PW - AKA CACTUS RED
Cactus Red
Post by Cactus Red » Tue Sep 25, 2018 11:53 am
2009 POWER WAGON, AKA, CACTUS RED 121036 MILES
CHINO VALLEY, AZ.
PRICE DROPPED TO $22,000.00, OBO
CONTACT 928 710 1044
THIS IS ONE OF ONLY 198 MADE IN 2009 FOR CIVILIAN USE, TOTAL PRODUCTION WAS 398
THE '09 FEATURES THE UPGRADED 5.7L HEMI W/ 383 HP, 404 FT/LBS TORQUE
TIRES ARE NEW IN APRIL OF 18, FIVE TOYO AT2 285/70-17 ON STOCK PW RIMS. WE WERE TOWING MORE, SO THE STOCK SIZE WAS USED.
ALL MAINTENANCE IS CURRENT - FRESH OIL CHANGE, TRANS SERVICE DONE 2018, F/R DIFF SERVICE 2018, TRANSFER CASE SERVICE 2018, PLUGS DONE AUG 2018. EXTENSIVE MAINTENANCE RECORDS ARE AVAILABLE - WE USED THIS TRUCK, BUT DEMAND RELIABILITY, SO IT HAD THE BEST POSSIBLE CARE. REAR DIFF WAS COMPLETELY REBUILT THIS YEAR BY THE DEALER. THE TRUCK DOES USE OIL WHEN TOWING, BUT IS WAY UNDER MOPAR USAGE GUIDELINES. DAILY DRIVING USES 1/2QT OVER 6 TO 7K. TRUCK HAS ALWAYS HAD MOBIL 1 SYNTHETIC IN IT.
CACTUS RED HAS BEEN USED AS A POWER WAGON IS INTENDED TO BE. https://youtu.be/7xy6RI4Pqfc
IT'S WELL PINSTRIPED, HAS DENTS/DINGS, REAR BED CORNERS ARE CUSTOM FORMED BY THE DESOTO MINE TRAIL. FRONT SEAT IS WORN AS YOU'D EXPECT FOR THE MILEAGE.
PARTIAL LIST OF ADDITIONS:
CUSTOM FACTORY ROCK RAILS - HAVE ADDED A STEP TO THEM BUILT FROM 0.18 WALL SQUARE TUBING W/ 1/8' DIAMOND PLATE TREAD.
FOX 2.0 REMOTE RES SHOCKS, FOX STEERING STABILIZER.
DUAL BATTERIES – ODYSSEY 65-PCT1750T ($276.00 EA) PURCHASED 05 SEPT 16 W/ BLUE SEA SWITCH TO COMBINE OR ISOLATE REAR BATTERY, 0/1 CABLE TO REAR BATTERY. WITH BOTH BATTERIES ON, THE WINCH IS VERY, VERY HAPPY.
DT PROFAB 0.50 OVER STOCK LENGTH KINKED FRONT CONTROL ARMS – WILL CLEAR 35 OR 37” TIRES.
DAYSTAR 1” FRONT LEVELING PUCK.
FIRESTONE REAR AIRBAGS W/ DAYSTAR CRADLES. THEY ARE THE REAR BUMP STOPS, MAKES FOR A VERY SOFT RIDE
KC 8” HID LIGHTS MOUNTED TO RANDY ELLIS DESIGN LIGHT BAR, LIGHTS ARE CONTROLLED BY DIMMER SWITCH OR CAN BE TURNED ON MANUALLY.
WARN WIRELESS REMOTE CONTROL FOR WINCH.
80’ OF 7/16 DIA 22,000 LB RATED SYNTHETIC WINCH ROPE.
SECONDARY TRANS COOLER.
AFE FINNED REAR DIFF COVER. HOLDS FIVE QUARTS OF GEAR OIL
PURPLE CRAINUIM HALF SPIDER DIFF GUARD.
AIRAID COLD AIR INTAKE WITH NON-OILED FILTER.
FLOWMASTER 40 SERIES MUFFLER.
DIABLOSPORT INTUNE TUNER.
BACKWOODS REAR BUMPER W/ LED REVERSE LIGHTS
ARE SHELL - REAR WINDOW LATCHES ARE WORN BUT WORK OK
OPTIONS:
YAESU FT-2900R TWO METER HAM RADIO W/ 5/8 WAVE ROOF MOUNTED LARSEN NMO ANTENNA $175.00
ARB 47L FRIDGE/FREEZER. PREWIRED IN CAB, OR PLUG INTO REAR BATTERY
$600.00
RECOVERY GEAR – WINCH LINE EXTENSIONS, TREE SAVER, SHACKLES, PULLEY BLOCKS, TOW STRAP, ECT - ALL THE STUFF YOU NEED FOR A POWER WAGON WINCH!
$600.00
Re: FOR SALE 2009 PW - AKA CACTUS RED
Post by FirerescuePW » Tue Sep 25, 2018 8:35 pm
Wow. Never thought I would see this...
Cactus Red
Post by Cactus Red » Tue Sep 25, 2018 10:27 pm
It's time. I have greatly enjoyed it, put a real amount of blood, sweat, and more than a few cuss words in to it. Lots of good memories for sure. But, it's time to make the changes needed to use our new camper more efficiently.
Post by RustyPW » Wed Sep 26, 2018 12:53 am
Sell you a 41ft diesel pusher. Cheap.
Mods to the PW; Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper , PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli G2 Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, BIG Pul-Pal, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, Carli Control Arms, Thuren 3" SoftRide Springs, Thuren Rear Shackles, MagnaFlow Muffler, Crown Stainless Brake Lines, MORE STUFF COMIN'.
Russ NRA Benefactor Member
Cactus Red
Post by Cactus Red » Sun Oct 07, 2018 5:05 pm
Dropping the price to:
$23,000.00 OBO
BoldAdventure
Post by BoldAdventure » Sun Oct 07, 2018 7:08 pm
You should mention this over on the FB Group >>> https://www.facebook.com/groups/860573913997932/ Lots more eyeballs.
Cactus Red
Post by Cactus Red » Sun Oct 07, 2018 8:08 pm
I don't have a Facebook account- never found it interesting. If it can be linked, I'd appreciate it.
Cactus Red
Post by Cactus Red » Thu Oct 11, 2018 9:37 am
