Best Drop Hitch (w/ball)
- Model Year: 2019
So the bottom line...considering the height of the receiver what is the best drop hitch that you’ve seen? Preferably keeping price in mind.
Re: Best Drop Hitch (w/ball)
I use a standard Reese 8”
16000 pounds max Gross Trailer Weight (3000 pounds max tongue weight) Titan by Reese
We also use a standard Reese 8”
Additions: Frame mounted .188 DOM 3" steel rock rails low profile steps; 1.5” Skyjacker leveling kit; Bully Dog GT Platinum SRT-10 A-pillar pod mount programmable performance chip, monitor, tuner; Linex Platinum OTR black armor bed & rock panel HD coating; matching Range Rider cab high fiberglass canopy; 2” Linex brush guard light bar w/ 4-KC Rally 400 Series 4” Halogen off road lights; S&B CAI; Flowmaster American Thunder cat back dual exhaust; Remote start; Hopkins Trailer Mate brake controller; Bearcat Pro 68XL CB; Mopar black accent fender flares; PW winch kit & remote control;
Updates: New Jasper Remanufactured 5.7 Hemi Engine (3 yr/100’000 mi warranty), Open Range All Terrain 35 x 12.5 x 17 MP3 10 ply E tires; McQuay-Norris Extreme ball joints (upper & lower); driveline u joints; fuel pump; 1 ton HEMI transmission cooler; OEM radiator; new front pinion seal & bearing; Denso 180 amp alternator, Interstate Mega-tron 850 CCA HD battery; water pump & serpentine belt; Bilstein 2 5100 shocks & steering damper.
I'm thinking I'll pick up a GEN Y hitch. There Torsion Flex boss hitch looks pretty slick (thanks RetiredBLM for previously suggesting).
The Curt ones stick out a little further, allowing me to drop the tailgate with the trailer hitched.
The Reese hitches are a little too short, and pulls the trailer into the truck enough that the tailgate won't fully open.
- Model Year: 2019
Thanks for the responses. It’s a bit of a trick due to the 2” lift and variety of trailers.
I use different tongue/ball mounts for all the different things that i tow around. So its always a 10 second deal to pull the single pin out of the receiver and slide in the different tongue. Down side is buying and keeping around the different tongues (but that's the price of being able to do a tool-less 10 second swap)HockeyWagon wrote: ↑Thu Jul 23, 2020 10:13 pmThanks for the responses. It’s a bit of a trick due to the 2” lift and variety of trailers.
Btw: In some states it is illegal to have the ball and tongue left on your vehicle when you aren't towing anything. I leave my receiver empty if I'm not towing - which also helps keep them from rusting in the NY salt bath.
I use a 2.5 in. Gen-Y. 6 in. drop/3 in. raise or flip for opposite. 3k tongue/21K tow. Cheap is subjective. The Gen-Ys aren't cheap in my book, but it's the last hitch I'll ever buy.
I’ve been enjoying my weigh safe hitch for the last couple years.
