Towing 8K lb trailer, Air Bags w/Cradles or WDH?
Re: Towing 8K lb trailer, Air Bags w/Cradles or WDH?
I was in commercial construction & used to tow a concrete form trailer before I retired. Heavier loads. Just never changed after retirement. Don’t use them if off road other than gravel mainlines so never felt the need.
Updates: Jasper Remfgr’d 5.7 Hemi Engine; Open Range AT 35x12.5 x17 MP3 10 ply E tires; Moog HD U/L front axle ball joints & wheel bearings; new link, sway, y bar & bushing assemblies; fuel pump; A/C exhaust fan & compressor;1 ton HEMI transmission cooler; OEM radiator; front pinion seal & bearing; Denso 180-amp alternator; Interstate 850 CCA HD battery; water pump, serpentine belt, Bilstein 2 5100 shocks/HD steering damper; F&R locker motors,sensors/u joints; 3" Magna flow cat back rear exit dual exhausts; Performance Brake/slotted rotor/caliper/pads/brake lines
Mule007 wrote:I was in commercial construction & used to tow a concrete form trailer before I retired. Heavier loads. Just never changed after retirement. Don’t use them if off road other than gravel mainlines so never felt the need.
Performance Mods:
Performance Mods:
