Towing advice
Towing advice
Post by Mule007 » Mon Oct 08, 2018 8:39 pm
Greetings; question: Curious what the opinions/ concern/ advice are for my friend who is thinking of a’14 PW Laramie w/ 6.4L w a 4.10 rear end on BFGoodrich 285/70R17 MT(?) tires. Their trailer is +/- 7600# loaded trailer they would be pulling. Have heard the Laramie PW is a heavier truck! Told them I would ask. Thanks in advance.
2005 Mineral Gray PW; #0666; frame mounted .188 wall 3" steel rock rails w/low profile steps; 2.5” Skyjacker suspension lift kit; Open Range All Terrain-35 x 12.5 x 17- MP3 10 ply,s; McQuay-Norris Extreme ball joints; T-steering upgrade w/Bilstein 5100 steering damper; updated Bilstein 5100 Mono tube nitrogen gas shocks; new OEM radiator; updated U-joints; Denso 180 amp alternator, Interstate Mega-tron 850 CCA HD battery; MoPar rear wheel well liners, black accent fender flares, remote start, Ravelco Anti theft device; Hopkins Trailer Mate trailer brake controller; Hemi 1 ton transmission cooler; Uniden Bearcat Pro 68XL CB radio; Linex Platinum black armor truck bed & lower rock panel armor coating; Matching Range Rider cab high fiberglass canopy; 2" Linex brush guard light bar w/ 4- KC HiLites Rally 400 Series 4" Halogen Driving/off road lights; Flowmaster American Thunder cat back dual exhaust; GT Platinum srt-10 A-pillar pod mount programmable performance chip, monitor, tuner; an S&B CAI; 60” Extreme High Lift jack& off road kit, bumper lift & tire lift kit; other rigging
Re: Towing advice
Post by Mule007 » Mon Oct 08, 2018 8:44 pm
The tires are D rated
Re: Towing advice
Post by Bill2014 » Tue Oct 09, 2018 9:24 am
The tires would be my first concern. I didn't find a BFGOODRICH in that size that was D rated - looks like they are C or E in that size - but I may have missed a tire...
Assuming the tires are not an issue, the Laramie wont have a problem with a 7600# trailer. If it's a camper, he should use a load distributing hitch...
Re: Towing advice
Post by TankerZak » Tue Oct 09, 2018 10:55 am
My 16 Laramie PW is on 37s and I tow 8500lb trailer. It's fine. It's NOT a diesel but it's fine if you know what to expect. Power band on gas is at about 4600 rpms so it grunts more on hills but i can still pass trucks doing 80 etc.
Re: Towing advice
Post by OffroadTreks » Tue Oct 09, 2018 11:57 am
Your friend will be fine. I've been pulling a trailer on three different tire sizes all over the place with my 2015 PW Laramie. With a family of 4 loaded up.
The stock D range Durtracs are pretty soft and squishy.
I was about 7000lbs during this photo, stock Duratracs:
The truck tows best with the stock tire size. That being said, I upgraded to a 35 inch Toyo Open Country AT/II after that, E range, a little bit heavier, but on level ground, you never noticed it at all. The 35's are the best size if you tow a lot in my opinion. It doesn't hamper your towing like the 37's will. Plenty of mountain passes with 35's.
I'm now towing on 37's, back in the D range.
Still no real issues. But the 37's make a noticeable feel/difference in power when towing. Even loaded up, when driving up passes that are over 7k feet, you feel the difference with the 37's vs the others. I didn't notice much of a difference going from 33's to 35's. But the 37's I have noticed the most.
I'll be regearing eventually here. But all around, I still manage with the 37's.
:cheers:
Re: Towing advice
Post by Mule007 » Tue Oct 09, 2018 7:44 pm
Thank you for the feedback; are the rear ends in a Laramie all 4.10? Also checked and the tires are Firestone! Appreciate the input 👍 but we have 35’s w @4.56 w no problems !
Re: Towing advice
Post by Mule007 » Tue Oct 09, 2018 7:47 pm
So wasn’t certain if the 4.10 would be an issue. Sorry for the gap answered the phone,,,
Re: Towing advice
Post by olyelr » Tue Oct 09, 2018 8:15 pm
All 4.5 gen power wagons have 4.10's. Its not an issue with stock size tires. But yea, 4.56's would certainly be a warm welcome back!
Re: Towing advice
Post by OffroadTreks » Wed Oct 10, 2018 10:27 am
Supposedly they dropped it when they added the extra gear in the transmission. Who knows. Rumor mill is 2020 HD's are getting an all new 8-speed.
4.10's are not an issue. All 6.4 motors or 4.5 gen's have the 4.10 gears.
Hasn't been an issue. Like I said, it's more noticeable going up to 37's. I'm going to 5.13's here when I get up to the secret Maple Wagon shop.
Re: Towing advice
Post by TankerZak » Wed Oct 10, 2018 10:52 am
If I change it'd be to 4.88s I think... but that is far from certian. Sometimes I'm in 2nd gear at 4600 rpm pulling hills. But I'm doing that at like 75 passing semi trucks. It's kinda what gears are for. If i was doing 35 or 40 in 2nd gear like my gramps old International pulling the boat with a camper on used too i'd be more inclined to regear.
But that's only since I went 37s. 35s were completely fine. At 37s you start to notice the breaks and the gears a bit more. It's not unmanageable but you notice.
Re: Towing advice
Post by Mule007 » Wed Oct 10, 2018 9:52 pm
Great input guys, much appreciated. Have passed your thoughts/experiences along along. The forum knowledge is incredible!!!👍. they are looking at options so will keep you posted!
Re: Towing advice
Post by Mule007 » Mon Nov 05, 2018 8:34 pm
FYI, They went w a ‘16, Ctd , Laramie! They didn’t,t think mainly tow and ” Glamp”
