Air compressor
verdesardog
Air compressor
Post by verdesardog » Fri Aug 10, 2018 9:56 am
I have a viair 200 psi OBA on my truck, love it for the engine brake, hair horn and airing up tires. I had an issue of it not holding pressure and running continuously. I did extensive troubleshooting and thought the compressor was toast so I ordered another one and replaced the alleged bad one. Same problem! I finally found a split air line that I could not get too or spray with soapy water so now I have a spare 200psi rated compressor. It has a 100% duty cycle at 100 psi so I made a portable out if it with a 125psi pressure switch, 200psi safety valve and a connection fitting. It turns on and off automatically as needed to keep the air line is pressurized. Instead of a typical cig. lighter connection or alligator clips I used power pole connections to mate with what I already have on my truck, no need to raise the hood.
Re: Air compressor
Post by Colibri » Fri Aug 10, 2018 10:09 am
That’s really slick! Nice work sir.
Re: Air compressor
Post by Mule007 » Sat Aug 11, 2018 9:28 am
Sweet; nice set up! 👍
2005 Mineral Gray PW; #0666; Laramie, Leather, dual cab control zones, power & heated seats, Alpine 9 speaker surround sound, steering wheel cruise, music & volume controls, 6 CD player, dark charcoal & silver interior.
Additions: Frame mounted .188 DOM 3" steel rock rails w/low profile steps; 1.5” Skyjacker suspension leveling kit; Bully Dog GT Platinum SRT-10 A-pillar pod mount programmable performance chip, monitor, tuner; Linex Platinum black armor truck bed & lower rock panel armor coating; Range Rider cab high fiberglass canopy; 2” Linex brush guard light bar w/ 4-KC Rally 400 Series 4” Halogen off road lights; S&B CAI; Flowmaster American Thunder cat back dual exhaust to rear; Remote start; Hopkins Trailer Mate trailer brake controller; Bearcat Pro 68XL CB radio; Mopar black accent fender flares; power wagon winch kit & remote control; Tools: 60” Extreme High Lift; hand tools, tow straps, shackles, chains, cables, off road rigging, 4 wheel tire chains, spare water & 2 rear wheel well NATO 20 L narrow gas cans.
Updates: Open Range All Terrain 35 x 12.5 x 17 MP3 10 ply E tires; 60,000 mi. warranty; McQuay-Norris Extreme ball joints (upper & lower); 1 ton HEMI transmission cooler; new OEM radiator; front & drive U-joints; 180 amp alternator, Interstate Mega-tron 850 CCA HD battery; new water pump & serpentine belt; new Bilstein 5100 shocks & steering damper.
Deyndy
Re: Air compressor
Post by Deyndy » Fri Aug 31, 2018 9:57 am
Nice work!
2017PW
Re: Air compressor
Post by 2017PW » Wed Jan 30, 2019 10:12 pm
Very nice!
