Air compressor
verdesardog
Air compressor
Post by verdesardog » Fri Aug 10, 2018 9:56 am
I have a viair 200 psi OBA on my truck, love it for the engine brake, hair horn and airing up tires. I had an issue of it not holding pressure and running continuously. I did extensive troubleshooting and thought the compressor was toast so I ordered another one and replaced the alleged bad one. Same problem! I finally found a split air line that I could not get too or spray with soapy water so now I have a spare 200psi rated compressor. It has a 100% duty cycle at 100 psi so I made a portable out if it with a 125psi pressure switch, 200psi safety valve and a connection fitting. It turns on and off automatically as needed to keep the air line is pressurized. Instead of a typical cig. lighter connection or alligator clips I used power pole connections to mate with what I already have on my truck, no need to raise the hood.
Re: Air compressor
Post by Colibri » Fri Aug 10, 2018 10:09 am
That’s really slick! Nice work sir.
Re: Air compressor
Post by Mule007 » Sat Aug 11, 2018 9:28 am
Sweet; nice set up! 👍
2005 Mineral Gray PW; Alloquin 3" rock rails w/low profile steps; 2.5" Skyjacker suspension lift kit; Toyo Open Country AT II Extreme-35 x 12.5 x 17 10 ply's; McQuay-Norris Extreme ball joints; T-steering upgrade w/Bilstein 5100 steering damper; Bilstein 5100 Mono tube nitrogen gas shocks; Denso 180 amp alternator, Interstate Mega-tron 850 CCA HD battery; MoPar rear wheel well liners, black accent fender flares, remote start, and Ravelco Anti theft device; Hopkins Trailer Mate trailer brake controller; Hemi 1 ton transmission cooler; Uniden Bearcat Pro 68XL CB radio; Linex Platinum black armor truck bed & lower rock panel armor coating; Matching Range Rider cab high fiberglass canopy; 2" Linex (matches Alloquin) round brush guard light bar w/ 4- KC HiLites Rally 400 Series 4" Halogen Driving/off road lights; Dyna-flow cat back dual exhaust; GT Platinum srt-10 A-pillar pod mount programmable performance chip, monitor, tuner; an S&B CAI.
