Wiring some lights...
Posted: Sun Oct 14, 2018 7:16 pm
this might be a little complicated. I would like to replace the factory fog lights on my 2013 with 4 2" led pods from blackoak. I would like one of the pods on each side to run as normal with the factory switch(on low beams as intended). On high beams, I would like all 4 pods to be manually activated by switch on the dash. Possible? how would I wire the low beam pods to fire with the switch when they are already wired into the factory switch? thanks
