Locker bypass kit
apalma302
Re: Locker bypass kit
Post by apalma302 » Sat Feb 03, 2018 6:25 pm
Count me in for both for my 2017 PW
AWST1230
Post by AWST1230 » Wed Feb 07, 2018 3:14 am
Interested in the new kit for the knob. 16 PW from The Great White North.
Post by FordyceCreekTrail » Thu Feb 08, 2018 7:45 pm
Where is the check out line for the Knob kit?
Zybane
Post by Zybane » Fri Apr 06, 2018 12:09 pm
Bump for v2 update!
AlaskaTRX
Post by AlaskaTRX » Sat Aug 04, 2018 1:15 pm
New to the board, but interested in this for my ‘17 once it’s available. Any update on this?
lancer29
Post by lancer29 » Tue Oct 09, 2018 12:02 pm
I am desperate need of help on this issue/fix for my 2005 as well. I would like to be added to the list if the purchase of something comes available.
2005 Dodge Power Wagon
1977 Ford Bronco
1980 Toyota FJ40
Blade
Post by Blade » Mon May 06, 2019 11:44 am
I am also looking into such a kit at the moment (or do myself)
As I understood so far, the problem comes from the electronic module inside the Smart bar, that controlls all the lockers and the sway bar.
Will this kit override this Smart bar control module if it fails for example? I want something 100% bullet proof as I will use the car in very remote areas. (sure, if the diff lock itself fails is another story)
Thnks for an input
Michel
2006 Dodge Power Wagon 2 door, planed to be used as an overland vehicle with a camper cabin
1972 Plymouth Road Runner 440-GTX, TX9 black with B5 blue interior and original airgrabber hood
Post by Retired BLM Rig » Mon May 06, 2019 1:33 pm
Thnks for an input
Michel
Here’s a link to the current locker bypass, contact me if you’re interested: viewtopic.php?f=43&t=5876
