17 dual alternator install
FordyceCreekTrail
Re: 17 dual alternator install
Post by FordyceCreekTrail » Tue Dec 05, 2017 8:25 am
Survived? Not well. I stalled my engine so many times back in the day I lost track, trashed batteries, trashed the cheap winch motors of the time, spent endless extra time winching waiting to build back juice..........And my personal favorite I had to hike out with a dead battery to recharge while tied to a tree on the side of a mountain.............Oh my, the good old days.....
Post by OffroadTreks » Tue Dec 05, 2017 11:30 am
I was just gonna say... but FordyceCreekTrail beat me to it. I've had old cars with small alternators and batteries. And yeah, you'd get stranded.
FordyceCreekTrail
Post by FordyceCreekTrail » Tue Dec 05, 2017 5:34 pm
You sure you did not edit your post? :doh:
mopar
Post by mopar » Wed May 16, 2018 7:31 am
Looking at a truck without it so found the part diagram here :
https://www.moparpartsoverstock.com/p/_ ... 648AC.html
wiring is there just need the belt the 0 gauge to battery cable and the dealer to flash xf5
jpostelle
Post by jpostelle » Fri Feb 22, 2019 4:53 pm
So,
I have purchased all the parts as listed from this forum , but are there any pictures or youtube videos of what an actual powerwagon dual alternator setup looks like? Thanks in advance for your help.
FordyceCreekTrail
Post by FordyceCreekTrail » Tue Mar 05, 2019 8:36 pm
I could post a few photos of my stock set up.
kgries
Post by kgries » Tue Apr 02, 2019 9:45 pm
I have dual alternators, but I would have rather had a higher power single and an air compressor in place in the second
Post by coder » Tue Apr 16, 2019 1:58 pm
Here's a pic from https://www.allpar.com.
jpostelle
Post by jpostelle » Wed Apr 24, 2019 1:09 am
So, went to a good friend of mine at Dodge Ram. Due to PCM restrictions and VIN mapping, even if I install all the parts and the wiring harness yhe PCM will not accept the flas code. RAM has started mapping all accessories to the vin and PCM. So my only recourse is to the 220 amp alternator. Hope I can recover some of the parts dollars I already spent. Bottom line newer vehicles you better make sure it has what you want or order it the way want.
Post by Reloaderguy » Wed Apr 24, 2019 9:02 am
Someone on CF did the install and it worked without adding sales codes. I'd do the install anyway.
Post by TankerZak » Wed Apr 24, 2019 1:55 pm
jpostelle wrote:So, went to a good friend of mine at Dodge Ram. Due to PCM restrictions and VIN mapping, even if I install all the parts and the wiring harness yhe PCM will not accept the flas code. RAM has started mapping all accessories to the vin and PCM. So my only recourse is to the 220 amp alternator. Hope I can recover some of the parts dollars I already spent. Bottom line newer vehicles you better make sure it has what you want or order it the way want.
There are some aftermarket alternators waaay bigger than 220 or even what the dual setup can provide. If the day comes my 180 isn't sufficient I'll try one of them. I think I saw a single 350 or 365 at some point...
Post by olyelr » Thu Apr 25, 2019 9:24 am
The dual setup is 380. But yes, the more I think about it I think one large one would be better.
I still like the idea to use a belt driven compressor in that second location for on-board air. :mrgreen:
Post by TankerZak » Thu Apr 25, 2019 9:41 am
olyelr wrote:The dual setup is 380. But yes, the more I think about it I think one large one would be better.
Yeah, that'd be nice. I'd love a belt driven compressor that could air up tires and airbags...
Post by olyelr » Thu Apr 25, 2019 12:06 pm
Air for daaaaaayyyyssssss lol
TommyDuncan
Post by TommyDuncan » Mon May 20, 2019 10:43 pm
My truck came with dual alternators and I don't really have any experience with them. I guess it will make winching easier...
Does anyone know if there is a way to charge the trailer batteries faster than through the 7 pin?
I have a blown up ARB dual compressor. Waiting to hear back from them on fixing it. Might get another one and put one or two tanks underneath for quicker air up.
