Page 21 of 22
Re: Hardwired Lockers with OEM Knob
Posted: Wed Apr 18, 2018 12:25 pm
by Reloaderguy
Retired BLM Rig wrote: ↑Wed Apr 18, 2018 10:24 am
I'll leave this here in case someone else in the future wants to hardwire their lockers from the SmartBar connector.
Can you identify what all of the pins are for?
Posted: Wed Apr 18, 2018 12:40 pm
by OffroadTreks
Reloaderguy wrote: ↑Wed Apr 18, 2018 12:25 pm
Here you go:
http://connectors.dcctools.com/details.htm?id=163539
Posted: Wed Apr 18, 2018 2:06 pm
by Reloaderguy
Does the Smartbar circuit board contain the transfer case position and speed limiting logic? If yes, can anyone identify the circuit path on the board?
Posted: Thu Apr 19, 2018 4:47 pm
by Retired BLM Rig
Reloaderguy wrote: ↑Wed Apr 18, 2018 2:06 pm
Based on the live data stream for the SmartBar, I would say yes.
I believe it passes right through the middle of the flux capacitor. If tampered with, it will interrupt the space time continuum resulting in your truck being filled with manure.
Posted: Fri Apr 20, 2018 8:32 am
Lmao!
I find it funny they have the speed set at 119 mph for the lockers to unlock lol
Posted: Fri Apr 20, 2018 11:11 am
by Bill2014
olyelr wrote: ↑Fri Apr 20, 2018 8:32 am
Lmao!
What????
you cant get to 119 mph in low range?
Have you tried??
Posted: Fri Apr 20, 2018 8:45 pm
Bill2014 wrote: ↑Fri Apr 20, 2018 11:11 am
Lmao!
What????
Have you tried??
No I guess not. I have been across the dunes in 4low in overdrive close to redline though... its nowhere near 119 mpg
Posted: Fri Apr 20, 2018 9:02 pm
by Reloaderguy
Has anyone tried either jumpering or splicing C to G and D to H inside the Smartbar or the wires outside? It seems the bar is being supplied power but then interrupting it in the logic board. That is essentially what the 4th Gen locker bypass is doing at the plug next to the computer. It'll throw a code but will be hard wired to the OE knob. Maybe a resistor or capacitor soldered directly onto the board can satisfy the position logic?
Posted: Sat Apr 21, 2018 12:00 am
by OffroadTreks
Why don’t you try it? And report back.
Posted: Sat Apr 21, 2018 10:29 am
by Reloaderguy
I probably will but it's going to be a while, I don't have a Smartbar in my truck and the factory wiring isn't running to my lockers.
Can I have your old smartbar?
Posted: Sat Apr 21, 2018 12:36 pm
by OffroadTreks
Mine is in route to PitSlave and my spare unit is promised now to another dude.
Posted: Sat Apr 21, 2018 12:46 pm
MikeKey wrote: ↑Sat Apr 21, 2018 12:36 pm
Mine is in route to PitSlave...
Im liking the sounds of this!
Posted: Sat Apr 21, 2018 8:40 pm
by Reloaderguy
I popped the hood today and started to get tools out to pull the module mounted behind the grill when I came to the realization I just don't care that much. Maybe when I do the steering or bumper I'll have more interest...or not. Either way, good luck to you guys.
Posted: Sat Apr 21, 2018 9:42 pm
by DamageWagon
^^^^^ the death of 98.7% of all projects
Posted: Sun Apr 22, 2018 10:00 am
by OffroadTreks
My shit works and that’s about the extent of my caring as well, lol
Posted: Sun Apr 22, 2018 10:09 am
by Reloaderguy
I already have a bypass. Maybe one of you guys that want to bypass your lockers can try jumping the pins i mentioned earlier and see what happens.
Posted: Sun Apr 22, 2018 11:45 am
by Retired BLM Rig
Reloaderguy wrote: ↑Sun Apr 22, 2018 10:09 am
I'm pretty sure that jumping those pins would result in a dead short and a blown fuse, unless I'm misunderstanding your meaning somehow.
Posted: Sun Apr 22, 2018 5:30 pm
by Reloaderguy
Retired BLM Rig wrote: ↑Sun Apr 22, 2018 11:45 am
Isn't the locker return the power source to the locker?
Posted: Sun Apr 22, 2018 9:13 pm
by Retired BLM Rig
Reloaderguy wrote: ↑Sun Apr 22, 2018 5:30 pm
Ah yes... Ram and their unfortunate choice of words for describing a circuit.
It's like they make it confusing on purpose.
As far as the locker actuators are concerned:
- "Source" means +12 Volt or power
- "Return" means -12 Volt or ground
- Pin #4 would be +12 volt coming from the SmartBar to the locker and Pin #6 would be -12 volt coming from the SmartBar.
On this image that I posted earlier, pins C & D would be
+12 volt/power being sent from the SmartBar to the locker actuators and pins G & H would be
-12 volt/ground being sent from the SmartBar to the locker actuators.
I know that technically electricity is always looking for the path of least resistance to ground and circuits are usually viewed as being a loop, so
+ is the source of power being sent out and
- is the return path to the ground that the electrons are looking for.
- In this image, substitute the word "Locker" for "Light Bulb/Load".
That's my best attempt at explaining why they use the terms "Source" and "Return".
Posted: Sun Apr 22, 2018 9:19 pm
by Reloaderguy
My volt meter would have stopped me from wiring the positive into the negative. LOL
So which is the locker power out from the smartbar?
Posted: Sun Apr 22, 2018 9:48 pm
by Retired BLM Rig
Reloaderguy wrote: ↑Sun Apr 22, 2018 9:19 pm
Pin C is power going out to the front locker.
Pin D is power going out to the rear locker.
Posted: Sun Apr 22, 2018 11:18 pm
by Low_Sky
BLM Rig, do you know if G/H are a common ground, or a floating ground that's only grounded when C/D are hot? If G/H are common and always grounded, one should be able to tap only into C/D right by the smart bar and save a lot of wiring. Would diodes be necessary to keep from back feeding +12V into the smartbar?
Posted: Mon Apr 23, 2018 2:37 am
by Retired BLM Rig
Low_Sky wrote: ↑Sun Apr 22, 2018 11:18 pm
Sorry I haven't had the need to test the ground side of the system yet, I don't know.
Yes, I would use diodes to protect the SmartBar if it was still going to be in the system. I would also use potted or weatherproof relays that have a built-in voltage spike suppressing diode or resistor like
this one to protect any delicate electronics that were still part of the system.
Posted: Mon Apr 23, 2018 12:04 pm
by Reloaderguy
That's what I was thinking. The locker power source is a connector on the passenger side of the rad, I'm just not sure which pins are the power in for the lockers in the Smartbar.
Posted: Mon Apr 23, 2018 5:02 pm
Reloaderguy wrote: ↑Mon Apr 23, 2018 12:04 pm
... I'm just not sure which pins are the power in for the lockers in the Smartbar.
Looks like they are C & D, no?
