One headlamp not working.
Ak68w
Post by Ak68w » Mon Jul 20, 2020 10:29 pm
2012 pw. My passenger side headlight is inop. Low Beam, high beam nothing. Running light works. I’ve changed bulbs, cleaned contacts, and after doing this twice, it worked intermittently a couple of times. I’m at a loss.
SeppW
Re: One headlamp not working.
Post by SeppW » Tue Jul 21, 2020 7:49 pm
Running OE bulbs (halogen I assume)? Any hotter and wire harness may have melted somewhere and is shorting out. How is the socket assembly? Check the whole harness for short to ground, major PITA though. Checked fuse and relay?
Ak68w
Post by Ak68w » Mon Jul 27, 2020 8:24 pm
Factory bulbs. Wiring harness looks good. I wasn’t aware there was a fuse or relay? I looked on the fuse box I. The engine compartment and couldn’t find one. Where is it located?
SeppW
Post by SeppW » Tue Jul 28, 2020 6:28 am
No fuse or relay, then could be the Total Integrated Power Module (TIPM). If it is, it is not not a cheap fix. You should be able to find the pin out on the Web and find the wire to the headlight and diagnose. The TIPM is not clear to me because under the PCM (or IPM) is where all the harnesses connect. I assume that is the TIPM.
If the dealer deals with it and it is the TIPM, you looking at least $1000.00 maybe more. Rebuilt TIPMS are abut 500 or so and can be replaced by you, but need to determine if the wiring is not the issue.
