19 ram power wagon screaming bigger
Posted: Sun Feb 02, 2020 8:28 pm
by Tryingitout
Hey I’m new to the forum.
Just bought a 19 power wagon but it’s screaming bigger. I was thinking 20” rims, 35” tires and maybe 12.5 wide..... anyone know if something like that without having to cut out wheel wells or rub anything would fit ?Image
Re: 19 ram power wagon screaming bigger
Posted: Sun Feb 02, 2020 10:10 pm
by Bill2014
No need to do 20" rims on the Power Wagon for 35's...
Posted: Sun Feb 02, 2020 10:12 pm
by OffroadTreks
Welcome. Please don't put 20's on your Power Wagon.
Posted: Sun Feb 02, 2020 10:19 pm
by KevinABQ
Stock wheels are not bad, unlike the stock duracraps. But if you want to change the wheels out this is helpful.
https://www.thurenfabrication.com/tech/ ... tment.html
Posted: Sun Feb 02, 2020 10:28 pm
by EasyDoesIt
Welcome. Please don't put 20" wheels unless you're going at least 37" if not 40" tires.
Posted: Sun Feb 02, 2020 10:34 pm
by Reloaderguy
31s are about the largest that will fit. Sorry.
Posted: Sun Feb 02, 2020 11:34 pm
by HockeyWagon
The natural inclination is to throw larger wheels and tires on the PW..and I thought about that as well when I first bought my PW. It really depends on what you plan to do with the truck.
If you plan on somewhat regular 4W drive or rock climbing trips I would stick with the stock wheel and tire size. This combo works great for full articulation. Remember competitive truck models to not have disconnecting sway bars so larger tires for example are fine. This truck really shines off road.
Posted: Mon Feb 03, 2020 12:45 am
37's on stock wheels will fit. Most go to 35's.
:winchmob:
Posted: Mon Feb 03, 2020 12:46 am
by DamageWagon
Would you like the 35x12.5 tires on 20” wheels from my truck? Image
Posted: Mon Feb 03, 2020 11:08 am
by Tryingitout
Thanks to all who replied. Sounds like 20” rims are not liked for this set up. Only reason I thought this was because I seen one with a 4” lift with 20” rims, and 37” tires and I’m geussing some offset. The stance on it got my attention. Thanks damage wagon it’s a nice set up you have but I’d probably stick with a black rim.
Posted: Mon Feb 03, 2020 11:12 am
by Tryingitout
Tryingitout wrote:Hey I’m new to the forum.
Thanks to all who replied. Sounds like 20” rims are not liked for this set up. Only reason I thought this was because I seen one with a 4” lift with 20” rims, and 37” tires and I’m geussing some offset. The stance on it got my attention. Thanks damage wagon it’s a nice set up you have but I’d probably stick with a black rim. ..... I’m not even sure I’m replying in the right place it doesn’t seem to want me to reply correctly
Posted: Mon Feb 03, 2020 11:53 pm
by btsbarton
Bigger tires? Hell yeah!
Bigger wheels? Hell no!
You won’t get much love for larger diameter wheels here. These things are off-road beasts and larger diameter wheels are more of a detriment off-road.
35x12.5R17 / 315/70R17 on stock wheels fit perfect, I’ve not noticed any rubbing turning or off-road. Photo of my 2019 on 315/70/17s attached.
I’ve heard 37s fit without any additional lift, but require some trimming, and you can’t fit a full size spare under the bed.
Posted: Tue Feb 04, 2020 3:06 am
by KevinABQ
I haven’t had to do any trimming and I’m running toyo 37x12.5 MTs on stock wheels. Rubbing and an increased turning radius, yes. But if I got better suited wheels I’d probably get rid of the rubbing and get most of the turn radius back.
