Apparently Toyo 37 MT are type 99 tires in bcm
Post by KevinABQ » Wed Apr 10, 2019 1:32 pm
Tech said he changed the tire type to that in the BCM and speedometer matches GPS now. Presumably after the series of other things you need to do to get that to take without alarms.
1pieceatatime
Re: Apparently Toyo 37 MT are type 99 tires in bcm
Post by 1pieceatatime » Wed Apr 10, 2019 2:31 pm
Mine go on tomorrow for PWIM. Hoping I don’t regret the MT choice next winter...
Post by olyelr » Fri Apr 12, 2019 8:21 am
If you think they are gonna not slip and slide around on the main roads you will be in for a treat!
kgries
Post by kgries » Wed Apr 17, 2019 1:09 am
What in the world does type 99 even mean lol, did he just change the tire size?
Post by Reloaderguy » Wed Apr 17, 2019 9:09 am
Mine handled snow and ice just fine this winter.
Post by Bill2014 » Wed Apr 17, 2019 12:08 pm
It's all relative - if you've only run M/T tires on a specific vehicle, then that winter performance is the "standard".
Large lugs without lots of siping are not ideal in the snow... :wink:
Post by Reloaderguy » Wed Apr 17, 2019 1:10 pm
Sometimes the internet doesn't deliver. This is one of those instances.
The guy I pulled out of Hyalite canyon with the siped ATs didn't ask why my truck wasn't slipping or how I managed the 700 mile snow storm.
Post by olyelr » Fri Apr 19, 2019 11:58 am
Yep, thats just it. Its all relative.
All I know is a good a/t tired would hands down out perform an mt on snow covered roads.
That being said, if the toyo mt is good enough, well then its good enough 🤘
Post by TankerZak » Fri Apr 19, 2019 12:22 pm
Snow is such a subjective term. Are you talking snow and ice covered roads, type of snow, snow depth? My highly siped Toyo RTs are great on snow covered roads but mediocre at best in deep snow. Honestly I'd rather buy a tire for deep snow (MT outter lugs and closer inner lugs) and use chains for ice if I have too...
Post by Reloaderguy » Sat Apr 20, 2019 12:39 pm
It's purely subjective. I think the poor snow and ice performance of MT's is overstated. This winter was particularly bad in the PNW and I had no issues. In one instance I drove 700 miles in a single continuous snow storm that was said to be the worst in 40 years. Conditions ranged from water ice to 2' of standing snow on 10" of hard packed ice.
Having worked in Zak's area I think siped aggressive AT's or hybrids is probably the best for his conditions. Portland gets ice storms that shut the city down. I've been there after the area got 1/2" of water ice, studs would have been best but that's a pretty expensive option given how limited the use would be.
Post by TankerZak » Sat Apr 20, 2019 6:58 pm
That being said, if the toyo mt is good enough, well then its good enough Image
I have no problem in town. But I think I need bigger lugs and more aggressive tread for deep snow. I'm really thinking about Cooper STT Pros after seeing them in person. I think the closer alternating 3 lug center will hold enough snow to add traction while keeping the deep lugs to clear. Idk... deep thoughts... and I won't execute until September or October... soo... months of me flip flopping around...
Post by olyelr » Sat Apr 20, 2019 10:01 pm
Well, a mt can perform better that an at or even a strickly snow tire in certain snow conditions, mainly like deep snow/powder situations.
But I dont care what anybody says... on most road travel situations i encounter, mt’s are hands down far worse that an at with siping. I would however like to try a siped mt... thinking that may be the best of both worlds?
