KM3
Punishher7
KM3
Post by Punishher7 » Mon Sep 10, 2018 11:06 pm
Is anyone here running the new BFG KM3 on their power wagon? I’m considering these in 35/12.5R17 on either the stock 2018 wheels or AEV Katla 17x8.5. Any input, photos, and initial impressions would be appreciated.
DrPW18
Re: KM3
Post by DrPW18 » Wed Oct 31, 2018 3:39 pm
315/70/R17 - stock PW rims - no rub yet. Great on highway, quieter then DURATRACs.
good ride at 68 psi x 4. can be up to 80. Just put these on.
DiazOsos
Re: KM3
Post by DiazOsos » Sat Nov 03, 2018 8:34 pm
Are the 315’s roughly 35” or 37” ? The Toyos are what I’m eyeing the most although km3’s and sst’s aren’t ruled completely out either.
Re: KM3
Post by RustyPW » Sat Nov 03, 2018 8:37 pm
315's are close to the 35's.
DiazOsos
Re: KM3
Post by DiazOsos » Sun Nov 04, 2018 7:50 pm
Thank you, I totally can’t decide between 35” and 37”. It’s the worst case of indecision I’ve ever had. I keep second guessing myself with the “ what if “ paradox.
Re: KM3
Post by OffroadTreks » Sun Nov 04, 2018 9:07 pm
I don’t even know why I bothered with 35’s. I love the 37’s more all the time.
Punishher7
Re: KM3
Post by Punishher7 » Sun Nov 04, 2018 9:14 pm
BoldAdventure wrote:I don’t even know why I bothered with 35’s. I love the 37’s more all the time.
For purely off-road the 37 totally makes sense. As my DD I’d like to squeeze every MPG I can out of my PW, while still being decent when we do go off-road. Do you recall the difference between 35s and 37s in day to day MPG?
Re: KM3
Post by DamageWagon » Mon Nov 05, 2018 4:19 am
If you’re a calm driver and go with a light or mid weight 37 you will probably see consistent or even improved mpg over stock.
Re: KM3
Post by OffroadTreks » Mon Nov 05, 2018 12:09 pm
I work from home, we don't commute. And to be honest, I don't track MPG's anymore. I make enough money. It's never been a concern.
Well until just this past trip to Moab. Milage was so bad, I took a cord of wood with me in the PW along with the Airstream, and filled up more than the last time I towed with the Airstream. Didn't really think the extra weight was that much, but apparently so. Guess it's time for gears.
Re: KM3
Post by KevinABQ » Mon Nov 05, 2018 12:36 pm
So what’s a light or mid-weight 37?
Re: KM3
Post by Reloaderguy » Mon Nov 05, 2018 12:57 pm
Probably a BFG because it'll actually be the size of a 33" Toyo.
Re: KM3
Post by olyelr » Mon Nov 05, 2018 1:01 pm
Not really sure there is a “light” 37 :lol:
Also, not just weight but less rolling resistance, like a true A/T or even a hybrid, will typically offer a bit better mpg’s as well as life/mileage out of the tire.
While not necessarily light (82 pounds!), I think the 37” Falken ATW3 would be a very nice true AT tire. I have read nothing but raves on that tire. There really isnt many out there to choose from for a true AT.
Re: KM3
Post by olyelr » Mon Nov 05, 2018 1:07 pm
Im curious, what does your 37” RT’s measure?
Re: KM3
Post by Reloaderguy » Mon Nov 05, 2018 1:31 pm
New they were less than 1/4" under 37". They have 24k miles on them now which is probably where the 37" BFG would be dry rotted, measure 32", and need to be replaced.
Re: KM3
Post by olyelr » Mon Nov 05, 2018 2:03 pm
:lol:
Re: KM3
Post by DamageWagon » Tue Nov 06, 2018 12:26 am
In my mind a light 37 would be a Yokohama MT, Toyo RT
Mid weight would be the Toyo MT 12.5-wide and most other 37’s
Heavy weight would be the Toyo MT 13.5-wide (actually 14.4 if I remember right) and other similar wide tires.
Rolling resistance, tread compound, weight, there’s lots of variables. The biggest variable is the driver.
Re: KM3
Post by RustyPW » Tue Nov 06, 2018 12:40 am
Torque on the nut behind the steering wheel.
16PW
Re: KM3
Post by 16PW » Wed Nov 07, 2018 12:00 pm
37x12.50 Cooper STT Pro's weigh 77lbs. That is what I just put on. That's pretty "light" for an 37 MT since pretty much all other major brands are over 80lbs. I say go with a 37. They look perfect on a power wagon. I would have been pissed if I went with 35's. MPG is not really a concern for me because it's bad either way.
