Finally got new tires for the 16.
waldo
Post by waldo » Thu Jul 12, 2018 12:41 pm
I had an old thread here last year about tires after a stick went through the sidewall of the OEM Duratrac. I got busy and never got around to buying new ones until now since they still had plenty of life left.
Anyway, I ended up with Mickey Thompson ATZ P3's.
Can't even describe how much better the truck handles on the roads here in WV. You no longer have to wait for the tire to decide to go along with the steering input in and out of the curves. No carcass roll like the Duratracs. I was able to just steer the truck through most of the curves that would have had me on the brakes with the OEM tires. Quiet too.
How they'll do in the snow is an unknown (until winter).
2007 and 2016 Power Wagons
Re: Finally got new tires for the 16.
Post by coder » Thu Jul 12, 2018 12:53 pm
I had the older Mickey Thompson ATZ's on my 07 the large tread blocks usually develop uneven wear pattern my personally like the Toyo RT's a lot better, 35's will fit your truck and would be a great choice.
waldo
Post by waldo » Thu Jul 12, 2018 1:09 pm
Too late now :P These are they newer design.We'll see how they wear. Got free lifetime balance and rotation. I stayed stock size because it barely gets under the garage door header as it is.
Post by coder » Thu Jul 12, 2018 1:40 pm
Got any pics?
Post by Bill2014 » Thu Jul 12, 2018 2:42 pm
What pressure did you run in the Duratracs when they would "carcass roll" on the highway?
waldo
Post by waldo » Thu Jul 12, 2018 3:01 pm
65-68. Really didn't matter. Felt like you were driving an unresponsive boat. Night and day difference.
waldo
Post by waldo » Thu Jul 12, 2018 3:06 pm
Got any pics?
Like I said, I have my reasons for not going bigger than stock.
Post by Bill2014 » Thu Jul 12, 2018 3:10 pm
So imagine what it must feel like for the guys that run the Duratracs at 40 psi :lol:
PWJouster
Post by PWJouster » Fri Jul 13, 2018 11:20 am
i ran them at 40 front and 36 rear cold.
yes they felt soft and added to the body roll feel but it was better at 40 then is was at 65
17 Method NV-Toyo RT 35
SPOD
FordyceCreekTrail
Post by FordyceCreekTrail » Sat Jul 14, 2018 8:44 am
I agree running my Duratrash at 40PSI after having 6 flats in Colorado on gravel roads, plus more on my road to my house, and not only have I not had another flat but they ride and handle better. Nervously twitching as I wait for my new tires.
Post by coder » Sun Jul 15, 2018 12:51 am
Nice looking tires they should serve you well.
Post by Mule007 » Sun Jul 15, 2018 8:27 am
Nice looking tread, they should wear well
2005 Mineral Gray PW; #0666; frame mounted .188 wall 3" steel rock rails w/low profile steps; 1.5” Skyjacker suspension lift kit; Open Range All Terrain-35 x 12.5 x 17- MP3 10 ply,s; McQuay-Norris Extreme ball joints; T-steering upgrade w/Bilstein 5100 steering damper; updated Bilstein 5100 Mono tube nitrogen gas shocks; new OEM radiator; updated U-joints; Denso 180 amp alternator, Interstate Mega-tron 850 CCA HD battery; MoPar rear wheel well liners, black accent fender flares, remote start, and Ravelco Anti theft device; Hopkins Trailer Mate trailer brake controller; Hemi 1 ton transmission cooler; Uniden Bearcat Pro 68XL CB radio; Linex Platinum black armor truck bed & lower rock panel armor coating; Matching Range Rider cab high fiberglass canopy; 2" Linex brush guard light bar w/ 4- KC HiLites Rally 400 Series 4" Halogen Driving/off road lights; Flowmaster American Thunder cat back dual exhaust; GT Platinum srt-10 A-pillar pod mount programmable performance chip, monitor, tuner; an S&B CAI; 60” Extreme High Lift jack& off road kit, bumper lift & tire lift kit; other rigging
Rodeoflyer
Post by Rodeoflyer » Sun Jul 15, 2018 12:34 pm
I hear the P3's are a totally different tire than the older ATZ's. I had them on my shortlist when I purchased new tires. I hear that Cooper makes the Mickey's now.
It's good to hear a positive review on them.
