Maxxis Tires
Posted: Mon Mar 19, 2018 9:19 pm
by Reloaderguy
Anyone here have experience with Maxxis tires on the street? I think I've seen one person in the FB PW group that had a set but he is Canadian. Any of you guys run a set of Trepadors radials or Razr MT's or know someone who has? Specifically the big hoops.
Re: Maxxis Tires
Posted: Mon Mar 19, 2018 11:34 pm
by Colibri
Gun45boat is the man to ask. He’s been running the treps in 50 and 42 for quite a while now
Re: Maxxis Tires
Posted: Mon Mar 19, 2018 11:49 pm
by Reloaderguy
Isn't he running competition compound bias plys?
Re: Maxxis Tires
Posted: Tue Mar 20, 2018 12:14 am
by DamageWagon
Reloaderguy wrote: ↑Mon Mar 19, 2018 11:49 pm
Why would you run anything else?
Maybe this solves the 40+” tire issue. Run 50’s and you won’t need fenders.
Re: Maxxis Tires
Posted: Tue Mar 20, 2018 1:03 am
by Reloaderguy
DamageWagon wrote: ↑Tue Mar 20, 2018 12:14 am
$800 per tire and 55mph speed rating doesn't exactly peak my interest.
Re: Maxxis Tires
Posted: Tue Mar 20, 2018 1:51 am
by DamageWagon
Reloaderguy wrote: ↑Tue Mar 20, 2018 1:03 am
Oh I’m sorry I didn’t realize we were trying to avoid compromises
Re: Maxxis Tires
Posted: Tue Mar 20, 2018 7:44 am
Theres a guy on here running the Razr’s on his ‘17, but only a 35” so probably would not be much of a review comparison for you.
Re: Maxxis Tires
Posted: Tue Mar 20, 2018 2:38 pm
by Reloaderguy
Pirate has a bunch of reviews.
Re: Maxxis Tires
Posted: Tue Mar 20, 2018 10:05 pm
For the radials? How they liking them?
Re: Maxxis Tires
Posted: Wed Mar 21, 2018 12:21 pm
by Reloaderguy
olyelr wrote: ↑Tue Mar 20, 2018 10:05 pm
Razr' S. They appear well liked. I'm also looking at MTZ P3.
Re: Maxxis Tires
Posted: Wed Mar 21, 2018 12:50 pm
by DamageWagon
Those Razrs look sweet, only $400 on Amazon and a 40,000 mile treadwear warranty (at least on the smaller sizes?)
Re: Maxxis Tires
Posted: Wed Mar 21, 2018 1:08 pm
by Reloaderguy
They're a lot less expensive than Toyos.
Re: Maxxis Tires
Posted: Wed Mar 21, 2018 1:53 pm
by NickTF
Would be nice to hear reports on how well they do or don't balance. 40k tread wear warranty on a 37" MT is interesting. E-rated tire as well although my d-rated toyos are as stiff as I ever need them to be.
Re: Maxxis Tires
Posted: Wed Mar 21, 2018 2:50 pm
by DamageWagon
Centramatic balancer would probably handle any balancing issues. D and E load range doesn’t mean anything realistically, ignore the load range. Load Index (the actual number in pounds that the tire can carry) is what matters. Sidewall stiffness and a tires ‘survivability’ are dependent on the tire itself and are not quantifiable measurements but you can get an estimate based on the tires weight, kind of. The D and E range Toyo MT in a 37” are the same carcass, the E range is physically larger and is designed to hold 65psi max vs 50psi. In comparison the Toyo RT and Nitto Ridge Grappler both lose load capacity when you go from a 12.5 to a 13.5 wide, even though max pressure is the same.
Re: Maxxis Tires
Posted: Sun Apr 08, 2018 10:52 pm
by whtpwrwgn
I've been running 35in razr mt for about 8 months now, no balance issues, run smooth for an mt, So far have been durable in rocks, great traction and tough sidewalls. I have some chunks missing from contact with a sharp fender. Wearing well.
- First waterfall on "elvis" in florence, AZ.
Re: Maxxis Tires
Posted: Tue Apr 10, 2018 10:51 am
by Reloaderguy
Thanks for the input. The Razr looks pretty good and the price is right. Maxxis is one of the few companies that makes a load index 128 40x13.5R20 and it's affordable.
