40-Inch Tire Discussion (Or anything bigger than 37's)
Re: 40-Inch Tire Discussion (Or anything bigger than 37's)
Post by BoldAdventure » Sat Mar 24, 2018 9:55 pm
None of us are truly into off-roading. This is a poser thread.
Post by Reloaderguy » Sat Mar 24, 2018 11:15 pm
I picked up 185 fender washers today to make a body lift.
Post by BoldAdventure » Sat Mar 24, 2018 11:35 pm
You could of used hockey pucks. I read it on pirate 4x4.
Post by BoldAdventure » Sat Mar 31, 2018 8:48 pm
I just want to leave this picture here, forever.
:popcorn:
Post by Bill2014 » Sun Apr 01, 2018 8:09 am
Looks kinda stiff - where’d the flex go? 😬
Post by olyelr » Sun Apr 01, 2018 10:56 am
Thats what happens when you use factory 2500 coils.
NovA ProspekT
Post by NovA ProspekT » Sun Apr 01, 2018 12:12 pm
:popcorn:
:run:
| 2007 Dodge Power Wagon |
[ My Flickr ]
Post by olyelr » Sun Apr 01, 2018 2:20 pm
Thats a cute spare tire.
Post by TwinStick » Sun Apr 01, 2018 8:47 pm
How much more do you think the rear would flex with the rear sway bar dis connected ? Or is it already ?
Traded to 2019 ZR2, Red.
Post by DamageWagon » Sun Apr 01, 2018 9:26 pm
It does flex a little better with the swaybar disconnected but it isn’t a huge difference. That is all spring in the lhoto
Post by olyelr » Sun Apr 01, 2018 10:20 pm
That truck above is using the factory 2500 springs, so that is a hindrance in comparison to a stock PW.
But, the truth is the rear suspension on the coil/linked trucks does not articulate as well as the older leaf sprung trucks. I am not sure if it is the relatively short arms and/or the bushing's used, or short shocks, or just the geometry or what. But they just dont seem to articulate very well.
Post by DamageWagon » Sun Apr 01, 2018 11:34 pm
You’re correct, the new trucks do not flex as well in the rear as the older leaf spring trucks do. Surprisingly the fronts are a match though. The reason the rear is hindered is that it is semi-triangulated (not a true, perfect 5-link) and is fighting bushings to flex. The older trucks have the same situation, it’s semi-triangulated, but the front has more weight so it’s easy to flex the fronts all the way, where the new trucks rears have a swaybar, stiffer springs, and less weight pushing on them.
Post by BoldAdventure » Mon Apr 02, 2018 12:04 pm
Here's another shot of an AEV Prospector flexing.
Oh wait..
yellowranger1
Post by yellowranger1 » Mon Apr 02, 2018 1:22 pm
:popcorn:
Post by Reloaderguy » Mon Apr 02, 2018 1:29 pm
How much flex does a diesel tow rig need? It's easy to make fun of AEV as they try to be everything to everyone but I don't think RTI numbers are their focus.
Post by BoldAdventure » Mon Apr 02, 2018 1:49 pm
So long as people continue thinking those trucks are something they're not and they continue to make exaggerative claims, they deserve to be ridiculed always.
Post by Reloaderguy » Mon Apr 02, 2018 2:15 pm
I guess but it's just repetitive and tiresome.
Post by BoldAdventure » Mon Apr 02, 2018 3:25 pm
:roll: then don't participate.
Post by nts007 » Mon Apr 02, 2018 7:55 pm
As much as mine has. Is the correct answer
Post by Reloaderguy » Mon Apr 02, 2018 11:28 pm
Post something fresh and new. We slagged AEV already, like two years ago.
Post by RustyPW » Tue Apr 03, 2018 1:51 pm
