Nitrogen in tires???
JFordBronco
Post by JFordBronco » Sat Feb 17, 2018 6:02 pm
Ok, so while I was in Waseca, MN house hunting last week, I had my "low tire" light come on. I checked the dash display and the tires were all low. Like 15+ pounds low. When I left from down here in Louisiana, the tires were at their recommended inflation. I understand there is a dramatic drop in temperature between here and there and the chaos that ensues with the tire pressure, soooooo, that being said, would it be beneficial to deflate my tires totally(or as much as I can) and have tire shop add nitrogen? I can get it done reasonably cheap. Anyone ever done that?
2015 Power Wagon
DocPaulo
Re: Nitrogen in tires???
Post by DocPaulo » Sat Feb 17, 2018 6:37 pm
Costco does it... just remember atmosphere is 78%nitrogen... so you're paying to get another 20% or so... helpful in high performance situations and racing where tires heat up between laps...
I think it was 15$ per tire or so
Auxbeam 42 curved lightbar
RANCHO 9000XL suspension
EMF ball joints
ghaugo
Post by ghaugo » Sat Feb 17, 2018 8:48 pm
We ran them with nitrogen at work, and my wife's car used to have it. It never made much of a difference. It was marginally better at keeping a stable pressure. I would just check them once and a while when you get big temp changes.
Aluminess Rock Sliders, Cooper STT Pro 315/70/17, ARE Z-Series Topper, FilterMag GP101 (front and rear diffs), DeeZee Tailgate Assist, Skanda Kryptec Typhoon seat covers, Husky X-act Contour Mats, Purple Cranium Diff Covers Front and Rear, Dodge Offroad Steering Brace, Volant CAI with Donaldson PowerCore Filter, Thuren Track Bar, Thuren Short Arms, Thuren Overland Shocks, All AMSOIL fluids from Code4Synthetics.com
Post by Ducky's Dad » Sat Feb 17, 2018 10:06 pm
It's an excuse to get on board air. Do it.
Post by nts007 » Sat Feb 17, 2018 11:07 pm
I use nitrogen for on board air. It works in tires. It also works air tools well with almost nil moisture. But you gotta pay to play right
DocPaulo
Post by DocPaulo » Sun Feb 18, 2018 10:24 am
That's probably quite the setup... pics? Specs? Probably cost a lot
EMF ball joints
Post by nts007 » Sun Feb 18, 2018 10:45 am
On my computer. I'll put them up tonight. The most expensive part was the tank and regulator. Other then that some connect couplings, copper pipe, feeder hose and some steel for the bracket and was all done.
Post by olyelr » Sun Feb 18, 2018 10:53 am
All the guess work is done with these kits. Not cheap, but nothing good is.
https://powertank.com
Rodeoflyer
Post by Rodeoflyer » Sun Feb 18, 2018 2:41 pm
I've been looking at the low pressure lights so long now I'm used to it. Temp changes affect pressure 10-15lbs.
I run my 35's at 30r/35f psi and they're wearing perfectly. I'll probably get 50k miles out of these cooper stt pros.
Post by RustyPW » Sun Feb 18, 2018 2:43 pm
N2 in tires for road going vehicles is snake oil. You can never get all the mixed air out and get close to 100% N2 in the tire. You will always have a mixture in there. The only way to have 100% N2 in the tire. Is to install the tire on the rim in an enclosed air tight chamber filled with N2. Air is already 78%. You paying someone to put N2 in your tires. Just send me the money instead. I worked for Goodyear way back when. We played around with N2 with other gases too. Moisture in the air is the biggest issue. If you use dry air. You would be better off. Most shop air compressors do not have dryers on the discharge side of it. So they have lots of moisture in the air. On my air compressor. I use a dryer set up with a collecting point to drain. Plus I drain the compressor after ever use.
Russ NRA Benefactor Member
Post by KevinABQ » Sun Feb 18, 2018 2:48 pm
N2 in tires for road going vehicles is snake oil. You can never get all the mixed air out and get close to 100% N2 in the tire. You will always have a mixture in there. The only way to have 100% N2 in the tire. Is to install the tire on the rim in an enclosed air tight chamber filled with N2. Air is already 78%. You paying someone to N2 in your tires. Just send me the money instead. I worked for Goodyear way back when. We played around with N2 with other gases too. Moisture in the air is the biggest issue. If you use dry air. You would be better off. Most shop air compressors do not have dryers on the discharge side of it. So they have lots of moisture in the air. On my air compressor. I use a dryer set up with a collecting point to drain. Plus I drain the compressor after ever use.
Iirc, eight total purges with argon was what you needed to produce an inert atmosphere in a glove box. I presume you could do that with nitrogen in your tires, but not sure about the payoff to do that.
Post by RustyPW » Sun Feb 18, 2018 11:29 pm
Cost vs benefit. Not worth it.
Post by Bill2014 » Mon Feb 19, 2018 8:33 am
I'm pretty sure that there is no measurable benefit in the Power Wagon using Nitrogen.
I typically only add air to my tires once a year - in December after the outside temp drops below 0 degrees.
AND - since we have TPMS, I never have to check the pressures with a gauge. :cheers:
DocPaulo
Post by DocPaulo » Mon Feb 19, 2018 6:05 pm
Considering we are overinflated to begin with unless towing... definitely no benefit... its just another moneymaker for tire shops
EMF ball joints
ramv
Post by ramv » Tue Feb 20, 2018 11:45 pm
If you have an easily corroded substance (bare steel wheels for example) pure, dry N2 may be worthwhile. Of course even liquid N2 isn't pure, and compressed N2 definitely isn't, typically still has some O2 and H20. In a truck tire, you shouldn't notice any difference between CO2 (much cheaper and more compact than N2 as it's stored as a liquid), N2, and good old air. I have all three in my tires. If you want to be all scientific, try one of each. If you see more than 5 psi difference, it would be worth a post!! (I haven't).
In drilling applications, it makes sense to use a N2 membrane unit to knock O2 out of the air to reduce drill pipe corrosion and potentially explosion when combined with hydrocarbons. In the tire world, none of this stuff makes a hill of beans. (Many of my customers use air rather than n2 for drilling as well...)
Post by RustyPW » Wed Feb 21, 2018 1:01 am
Talking about gases. Most large power plants use hydrogen to cool their generators. :shock: We used to go through a large semi trailer worth in a month.
Post by Bill2014 » Wed Feb 21, 2018 9:35 am
Some of us make our own large volume - Ultra High Purity N2 (and other gasses) at work. :wink:
But even having access to it for free, there is no measurable benefit in the Power Wagon wheels using Pure Nitrogen.
