Largest tire practically possible on a stock '12
Got a '12 PW that is stock in terms of suspension and wheels. Anyone know the largest tire I could put on it without any significant rubbing or other issues? I don't feel like doing any mods at this point to get tires to work. I appreciate any input. I searched for the answer but didn't find anything definitive. (I'm sure this question has been asked...)
Re: Largest tire practically possible on a stock '12
Without any real changes, you can run 35’s with maybe some trimming of the plastic liner. You’d be best to swap wheels to a slightly wider offset if you want to go 37’s.
From that, it sounds like running 285-75-17 (~34") or 295-70-17 (~33.5" but obviously wider) sizes would be fine. Sound about right?
