Going without TPMS Sensors
TommyG
Post by TommyG » Tue Sep 01, 2020 8:56 am
Thinking of doing wheels when I replace the tires this fall. Beyond the light on the dash which I have had for years and don't mind, is there any adverse operation triggered by running aftermarket wheels with no sensors? I know I won't see tire pressures on the dash - don't mind that.
Thinking I am just going to sell the OEM wheels with the tires on them and don't want to mess with the sensors if I don't have to. They should get snapped up pretty quick here locally.
To my PA brothers - will it pass Inspection with completely inoperable TPMS?
SimonandSimonBeast
Re: Going without TPMS Sensors
Post by SimonandSimonBeast » Tue Sep 01, 2020 2:52 pm
I can't speak to passing inspection. When I ordered new wheels / tires, I just ordered them with sensors in and tires mounted and balanced. I used my AEV Procal to set the alarm at a min of 35 psi. That is what I run my rears at, so no alarms until I air down for off road.
:rockon: :chug:
EasyDoesIt
Post by EasyDoesIt » Tue Sep 01, 2020 2:54 pm
My tpms saved me fender when I had a fast leak on the highway. If my tpms didn't start yelling at me, it probably would have shreaded the tire into my fender before I noticed (been there done that in a different truck).
But to each there own.
SimonandSimonBeast
Post by SimonandSimonBeast » Tue Sep 01, 2020 2:58 pm
TireRack states "No" for PA. Not required to operate.
:rockon: :chug:
pdavey
Post by pdavey » Tue Sep 01, 2020 3:21 pm
You would be better off getting the Alphaodb software and changing the thresholds in the computer then deleting it entirely. I set mine for 45 psi as that is what I run most of the time.
Since I tow a travel trailer having the TPMS is fairly important.
Performance Mods:
Other Mods:
Suspension/Protection Mods:
Style/Other Mods:
TommyG
Post by TommyG » Tue Sep 01, 2020 4:39 pm
I am going to grab Alpha OBD eventually but it won't do me any good with TPMS if the new wheels don't have any sensors in them.
pdavey
Post by pdavey » Tue Sep 01, 2020 5:01 pm
Just have them move the sensors from your old wheels when you get them mounted. Then you keep the sensors and don't have to go through a re-learning process.
Performance Mods:
Other Mods:
Style/Other Mods:
Oilbrnr
Post by Oilbrnr » Tue Sep 01, 2020 7:03 pm
I wouldn't eliminate them. Heck, I use them to monitor tire temps when running long stretches air'd down (less than 20 psi).
'16 with '17 FWC
SimonandSimonBeast
Post by SimonandSimonBeast » Tue Sep 01, 2020 7:54 pm
Yeah, I find the TPMS helpful when the seasons change. I take a peek to see if I need to up the pressure in any of the tires without having to get a guage out. Also, I have Alpha OBD in addition to Procal, but have never had to reprogram after I did the low pressure setting on Procal, regardless of what the instruction said about the permanency. The Alpha OBD does more so it is a better value. Hindsight is 20/20 they say.
:rockon: :chug:
SimonandSimonBeast
Post by SimonandSimonBeast » Tue Sep 01, 2020 8:25 pm
One other thing. I've changed sensors twice (I have a '13). Once on my stock wheels just because they were end of life. There is a battery in each sensor that eventually dies, like any battery. They didn't all go out at once, so the cost was spread out. And then when I bought the new rim/tire combo. Considering the overall investment, it was only a little more to have them installed. They self program when you get up to speed for a mile or so. I also recommend preordering a ceramic coat on your new rims. Again, just a little more to protect the investment. So far I haven't had to scrub my rims. They seem to come clean with a regular car wash. They barely hold any dirt build up as it is.
:rockon: :chug:
Post by RustyPW » Tue Sep 01, 2020 9:20 pm
I haven't had tire sensors in years. Never had a problem with state inspection either.
SimonandSimonBeast
Post by SimonandSimonBeast » Tue Sep 01, 2020 9:57 pm
TPMS and smart phones. What would we ever do....Russ?
:rockon: :chug:
SimonandSimonBeast
Post by SimonandSimonBeast » Tue Sep 01, 2020 10:07 pm
TPMS reports....Image
:rockon: :chug:
