Hi guys,
does anyone know where I get the bushing from the front control arm? FCA didn't list them and they told me to buy complete new control arms after 100.000 miles which cost almost $900 for both sides. Only because the third bushings are nowhere listed. One of it is screwed up and I have aditional noises, when I drive over litte bumps...
Maybe someone knows an alternativ product from the aftermarket? Also control arms would be interesting instead of the OEM ones.
The three big bushing for eacht control arm I have already, but I can't find the small one...
Here are two pictures of what I mean, eclosed.
Thanks for your help!
PW 2015 - Front axle bushings
Re: PW 2015 - Front axle bushings
Try http://moparpartsgiant.com/ have a wide range of parts or advise on where to find',,,,
Here are the part numbers I came up with for control arm bushings:
Mopar - 68205913AA - $130.40
Moog - K201767 - $8.39
The control arms are available on RockAuto.com
Mopar - 68195544AE - Right/passenger side $501.99
Mopar - 68195545AE - Left/driver side $462.79
Check your own part numbers based on VIN number to be sure.
