Factory Rake
Punishher7
Factory Rake
Post by Punishher7 » Thu Jul 18, 2019 5:54 pm
Is there a spring available for the rear in order to maintain the factory rake with the Thuren 1.5 inch lift?
Oilbrnr
Re: Factory Rake
Post by Oilbrnr » Thu Jul 18, 2019 6:27 pm
Yeah. AirLift. ;-)
You can ask Chris, but Don felt their other rear spring options a couple months ago (think for the Cummins) was too stiff, even in my application that has a lot of weight in the back. Shell, fridge, rack, solar, extra battery etc.
'16 with '17 FWC
Punishher7
Factory Rake
Post by Punishher7 » Thu Jul 18, 2019 7:07 pm
Maybe I should have been more clear. I want to keep the factory rake while unloaded and not towing. I’m not a fan of the nose high look trucks get when leveled. I appreciate the info though.
Re: Factory Rake
Post by Reloaderguy » Thu Jul 18, 2019 8:52 pm
1" rear spring spacer.
Re: Factory Rake
Post by TankerZak » Thu Jul 18, 2019 10:53 pm
Reloaderguy wrote:1" rear spring spacer.
What he said. I shoulda added that spacer from the start. I added it later with just the front springs and still have it installed with Kings and full Thuren.
2016 Granite Crystal Metallic Power Wagon Laramie, graphics delete, debadged, Thuren front and rear coils, Thuren rear swaybar links, Thuren rear trackbar, Traxada rear 1 inch spacers, King 3.0 (Stage 4) front and 2.5 (Stage 3) rear shocks, Boogie front bump stops, Cooper STT Pro 37x13.50R17 on XD Machette 17x9 +18 wheels, DOR steering brace, Thuren King Steering Damper, Synergy Steering Kit, Thuren PW bumper, White Knuckle rock sliders, Dethloff skid plate, Purple Cranium Half Spider front and rear diff guards, Airlift Ultimate airbags with Daystar cradles, Bakflip Revolver X2 tonneau, AMP BedStep, Factor55 Ultrahook with 100ft 7/16 A.R.E. Spidersilk synthetic winch line, Zroadz Grill with slim 20 inch light bar, DDM Tuning LEDs/HIDs, Magnaflow 19200 modified with upgraded resonator and after axle dump, tinted front windows 35%.
Re: Factory Rake
Post by Low_Sky » Fri Jul 19, 2019 1:04 am
Punishher7 wrote:Is there a spring available for the rear in order to maintain the factory rake with the Thuren 1.5 inch lift?
1” coil spacer
Punishher7
Re: Factory Rake
Post by Punishher7 » Fri Jul 19, 2019 1:40 am
Thanks gents!
