Does the Sway Bar Disconnect ever work?
FordyceCreekTrail
Post by FordyceCreekTrail » Tue Jul 09, 2019 6:40 pm
Or is it just a POS Ram refuses to fix? Mine has never worked. Rarely unlocks and right now its been flashing since the last trip and wont re-engage. Pretty silly to have it when I am too scared to use it knowing its unlikely to work. Front locker wont ever work either, but the bi-pass kit took care of that. Asking the dealer to look at it again this week.
Last edited by FordyceCreekTrail on Wed Jul 10, 2019 8:48 am, edited 1 time in total.
Oilbrnr
Re: Does the Sway Bar Disconnect ever work?
Post by Oilbrnr » Tue Jul 09, 2019 7:54 pm
Meh, my disco works fine (obviously it can't be bound up to disconnect) and so does the rear locker. Front can be a bit more finicky.
'16 with '17 FWC
Post by Mule007 » Tue Jul 09, 2019 8:47 pm
:wink: FWIW; mine always has,, and still does work
Additions: Frame mounted .188 DOM 3" steel rock rails w/low profile steps; 1.5” Skyjacker suspension leveling kit; Bully Dog GT Platinum SRT-10 A-pillar pod mount programmable performance chip, monitor, tuner; Linex Platinum black armor truck bed & lower rock panel armor coating; Range Rider cab high fiberglass canopy; 2” Linex brush guard light bar w/ 4-KC Rally 400 Series 4” Halogen off road lights; S&B CAI; Flowmaster American Thunder cat back dual exhaust to rear; Remote start; Hopkins Trailer Mate trailer brake controller; Bearcat Pro 68XL CB radio; Mopar black accent fender flares; power wagon winch kit & remote control; 60” Extreme High Lift; hand tools, tow straps, shackles, chains, cables, off road rigging, 4 wheel bad weather tire chains, spare water & 2 each extra 5 gallon narrow military jerry cans.
Post by Reloaderguy » Tue Jul 09, 2019 8:51 pm
I took mine out and installed a Thuren sway bar.
Post by FirerescuePW » Tue Jul 09, 2019 10:13 pm
Mine works. You've forced all of us to jinx ourselves.
Post by RustyPW » Tue Jul 09, 2019 10:31 pm
My new one works fine. The old one worked great right up to the point where it quit.
Post by Low_Sky » Wed Jul 10, 2019 12:06 am
My 2015 swaybar works fine, gets used a lot.
FordyceCreekTrail
Post by FordyceCreekTrail » Wed Jul 10, 2019 8:47 am
Damn, mine NEVER has worked. Just assumed they were junk. Will be out of warranty now as well. Sorry meant front locker never works, duh.
Post by OffroadTreks » Wed Jul 10, 2019 10:26 am
Mine has always worked. Right up until the point I went manual.
PWJouster
Post by PWJouster » Wed Jul 10, 2019 10:50 am
mine worked fine...albeit, if 4low and under 18MPH is fine for you...
On demand switch and air release is something i use EVERY DAY.
i disconnect once i get on the highway, 90MPH and 10 miles later i re egnage just before the exit turn ramp so i dont have to slow down.
Over 65MPH without a front swaybar and Thuren tuned Kings is a ride you dont forget(compared to any other HD)
Post by Low_Sky » Wed Jul 10, 2019 1:01 pm
PWJouster wrote:mine worked fine...albeit, if 4low and under 18MPH is fine for you...
Swaybar disco works in 4HI too.
Oilbrnr
Post by Oilbrnr » Wed Jul 10, 2019 1:11 pm
Correct me if I'm wrong, but no one offers a bypass module to let the disco work on demand?
'16 with '17 FWC
Post by olyelr » Wed Jul 10, 2019 1:42 pm
Nope.... but maybe retiredblmrig is being hush hush about attempting such a feat?! :idea: :excited:
Could always go the manual route or the air actuated route.
PWJouster
Post by PWJouster » Wed Jul 10, 2019 3:40 pm
Evo mfg on demand air release is the only truly ON demand anytime option right now...again, right now...
Oilbrnr
Post by Oilbrnr » Wed Jul 10, 2019 5:19 pm
I looked into the Evo after reading one of your posts awhile ago. Didn't you say that you left the OEM actuator connected though to keep from throwing errors?
I'm not opposed to routing an airline from my tank along with the other associated paraphernalia, but it'd be nice just to use the stock buttons. :D
'16 with '17 FWC
Mule
Post by Mule » Wed Jul 10, 2019 7:58 pm
Mine works great. Shift into 4 (high or low), press the button, light blinks... if it doesn't disengage in a second or two, a wiggle of the steering wheel to unbind things is all it takes.
Lockers are the problematic feature.
Rodeoflyer
Post by Rodeoflyer » Wed Jul 10, 2019 11:07 pm
4hi under 18mph woohoo
PWJouster
Post by PWJouster » Thu Jul 11, 2019 8:41 am
exactly lol sway bar disco isnt only usefull when rock crawling...its necessary on high grade fire roads, or any type of 18+MPH overlanding.
with the Evo air release, you do still want to keep the stock module tucked under there so you dont throw codes.
Yes, you need a switch, but plenty of places to install to make it look OEM. And, it has an audible engagement or "disengagement", which is nearly instantaneous on flat ground, and it will reengage the swaybar nearly instantaneous as long as your on flat ground when you click off.
at least you can hardwire bypass the stock locker knob!
Post by Retired BLM Rig » Tue Jul 16, 2019 1:54 am
Shhh... 🤫
Undocumented spy photo.
Elec. S.B..JPG (17.77 KiB) Viewed 1047 times
Oilbrnr
Post by Oilbrnr » Tue Jul 16, 2019 2:13 pm
Manual huh BLM?
Is a interface module just to complex an ask given the programming and hardware requirements? I'm assuming it is, otherwise the jeep aftermarket would have addressed it.
'16 with '17 FWC
Post by olyelr » Tue Jul 16, 2019 6:04 pm
Shhh... 🤫
:shock:
:popcorn:
Post by Retired BLM Rig » Wed Jul 17, 2019 1:41 am
Manual huh BLM?
Standalone, electric sway bar disconnect with the flip of a switch. Currently testing the prototype on my truck. It will work on any SmartBar, PW or Jeep. Does not use the factory switch, OEM module will have to be secured to the frame, crossmember or engine compartment to retain locker function and eliminate trouble codes. Working out the details. Anybody know a good patent attorney? :patriot:
PWJouster
Post by PWJouster » Wed Jul 17, 2019 9:52 am
cant wait to see how you accomplish this.
My question is the motor/servo you will use to accomplish this, and if off camber engagement or disengagement will create stress on the actuator as its working against the load on the pin.
With the Air, its a solenoid that opens and closes, and the swaybar module itself is not powered.
Powerwagon crew could not be any more lucky with a team member like you
:notworthy: :lockedandloaded:
Post by olyelr » Wed Jul 17, 2019 9:58 am
Manual huh BLM?
Take it to the shark tank :lol:
