05 PW Shock Lenghts
Rob-Pod
05 PW Shock Lenghts
Post by Rob-Pod » Sun Oct 07, 2018 10:30 am
As I'm gearing up to do my swap, I'm getting different info.
Does any1 know the Actual Lengths for front n rear shocks?
I'm looking for both expanded n collapsed lengths please.
I'm looking into getting the Bilstein 5160 Res Shocks.
My mega cab (getting PW suspension, axles, & winch)
already has a (1.5") coil spacer and I will prolly do a
Shackle in the rear for another .75"/1" lift out back.
Thanx,
Rob
Re: 05 PW Shock Lenghts
Post by DamageWagon » Sun Oct 07, 2018 4:55 pm
I don’t know the lengths off hand. 16.5” sounds familiar as a starting point but you’ll need to measure with the springs and bump stops removed and the axle sitting metal to metal.
Shock length is ALWAYS driven by the fully compressed dimension and whatever lift height you’re at has no bearing on shock length. You want the longest collapsed dimension you can get when the truck is at full bump. However much travel that gives you is going to vary based on what shock design you choose.
Rob-Pod
Post by Rob-Pod » Sun Oct 07, 2018 6:42 pm
In my almost 3 years of owning my PW, I've Never taken it hardcore off roading.
I prolly wont with the MC Either. I'm trying to order my shocks Before I tear the
trucks apart, so I don't have to deal with doing it after putting it back together.
Post by olyelr » Sun Oct 07, 2018 9:27 pm
You have a pw? Worst case, just unbolt the lower bolt for one front shock and one back shock, and get the collapsed and extended measurements.
Post by RustyPW » Sat Oct 13, 2018 10:05 pm
Believe coder has the dimensions.
Post by coder » Tue Oct 16, 2018 12:58 pm
Here you go:
OEM Measurements:
Front:
Total length end to end: 29"
Length end of bolt to center of eye: 28"
Rod length to end of bolt: 12.75"
Compressed front overall end to end: ~ 19.5"
Rear:
Total length end to end: 30 3/8"
Length center of eye to center of eye: 28 3/8"
Rod length to end: 13.25"
Rod length to center of eye: 12.25"
Compressed rear overall end to end: 20"
Post by Mule007 » Tue Oct 16, 2018 2:31 pm
Good info; thank you!
Additions: Frame mounted .188 DOM 3" steel rock rails w/low profile steps; 1.5” Skyjacker suspension leveling kit; Bully Dog GT Platinum SRT-10 A-pillar pod mount programmable performance chip, monitor, tuner; Linex Platinum black armor truck bed & lower rock panel armor coating; Range Rider cab high fiberglass canopy; 2” Linex brush guard light bar w/ 4-KC Rally 400 Series 4” Halogen off road lights; S&B CAI; Flowmaster American Thunder cat back dual exhaust to rear; Remote start; Hopkins Trailer Mate trailer brake controller; Bearcat Pro 68XL CB radio; Mopar black accent fender flares; power wagon winch kit & remote control; 60” Extreme High Lift; hand tools, tow straps, shackles, chains, cables, off road rigging, 4 wheel bad weather tire chains, spare water & 2 each extra 5 gallon narrow military jerry cans.
Rob-Pod
Post by Rob-Pod » Thu Oct 25, 2018 5:35 pm
Here you go:
OEM Measurements:
Front:
Rear:
Kewl, Thanx.
Rob-Pod
Post by Rob-Pod » Fri Dec 21, 2018 4:47 pm
Any1 here Running Bilstein 5160s or even 5100s
on there PWs? Do you remember your Part #s?
I'd like to stay will Bilsteins, but I'd really like to have Res
Shocks. Who else makes Reservoir Shocks 98% for the look.
I'm not doing Raptor/Baja stuff with it, so no $2000+ sets.
Post by Mule007 » Fri Dec 21, 2018 5:21 pm
Running 5100’s; can’t read the parts#,s. Lief Gregory , 2005 Power wagon forum oriniator, in his original specs listed the following info for our shocks: 5100 40 mm Bilstein nitrogen charged shocks. Front: 52121451AC ; Rear: 52121458AB. He noted these #, did not cross reference& another Un named member had suggested it may be BE 5 2459. Color code ‘HO’ ( yellow & blue). When had mine redone gave this info to our mechanic and he was able to find them but couldn’t,t find the receipt. Me be someone else has more info. Hope this helps!
bulldog59
Post by bulldog59 » Sun Apr 07, 2019 3:09 pm
Mule007 wrote:Running 5100’s; can’t read the parts#,s. Lief Gregory , 2005 Power wagon forum oriniator, in his original specs listed the following info for our shocks: 5100 40 mm Bilstein nitrogen charged shocks. Front: 52121451AC ; Rear: 52121458AB. He noted these #, did not cross reference& another Un named member had suggested it may be BE 5 2459. Color code ‘HO’ ( yellow & blue). When had mine redone gave this info to our mechanic and he was able to find them but couldn’t,t find the receipt. Me be someone else has more info. Hope this helps!
These mopar numbers are not for a power wagon I checked with a dealer. Does anyone have the original bilstein part number that was stamped on the shocks? Mine are to rusted to read. I called bilstein directly and they had no listing for a power wagon. Any info and help would be appreciated.
