Thuren Rear Sway Bar Link Clearance Issue W/ Diff Guard
Chromolykid
Re: Thuren Rear Sway Bar Link Clearance Issue W/ Diff Guard
Post by Chromolykid » Wed May 30, 2018 1:15 pm
TankerZak wrote:
Tue May 29, 2018 7:18 pm
I think Marcus installed mine upside down so the zerks were protected.
I assumed that was the “right-side up” way.
Well glad to see I’m not the only one that came across the issue, luckily I don’t typically have the truck weighed down so the removed bar is hardly noticeable. Just wanted to put the info out there for future reference, might save somebody the head-scratching.
“Furiosa”
2016 Power Wagon
White Knuckle Sliders
DOR Steering Brace
Thuren Stage 1 KING 2.5’s
Thuren Coils Front & Rear
AEV Procal
Post by PWJouster » Thu May 31, 2018 11:42 am
maybe this is the clunk i hear/feel swallowing speed bumps on road... if it wasnt monsooning, i would check for damage
17 Method NV-Toyo RT 35
SPOD
Post by DamageWagon » Thu May 31, 2018 11:50 am
That time of the month huh? Most guys wouldn’t want to crawl underneath either
Post by BoldAdventure » Thu May 31, 2018 11:51 am
Easttnrhino wrote:
Wed May 30, 2018 12:10 pm
I apologize if my view differs from yours. I know we all use our trucks differently also, so our choices will be different. If I came off as my way is the only way I am sorry.
I didn't take it that way at all. That was just an in jest reply. :cheers:
I spent most of PWIM with it removed because it does ride better. But once the tent is on, or the Airstream hooked up, it's needed. I've been thinking about making quick disconnects for fast removal for crawling stuff. But a couple bolts isn't bad either. We shall see if I get around to it.
Check your mounting bushings. Somehow my front driver side bushing on top of the shock is already torn and needs replaced. Depending on what I hit in the road, it will make a clunk noise.
Post by PWJouster » Thu May 31, 2018 12:06 pm
over tightening on those bushings in a pintop style will create great torsional stress... lots of sounds on wranglers from these.
i did think the bushings looked alittle too oblong and overcompressed. on the jeep jk, we used a certain grease to lube the contact surfaces on these bushings.
ill check them out.
SPOD
Post by DamageWagon » Thu May 31, 2018 1:38 pm
Lubing pintop bushings isn’t going to do anything to help them, there is no movement except the compression of the rubber itself. Pintops suck but there’s no getting around that with bolt-in parts.
Post by Colibri » Thu May 31, 2018 11:22 pm
I think he just means to stop them squeaking?
Post by BoldAdventure » Fri Jun 01, 2018 10:01 am
Used to do that on poly bushing on the Camaro, they came with grease.
Post by PWJouster » Fri Jun 01, 2018 1:26 pm
youd be surprised by the amount of noise over compressed bushings make if you havent experienced it.
grease worked in the past.
i boogied in the yard last night and the suspension cycle sure does make alot of noise. rear sway bar is eating away at the sticker on the rear spider. maybe no sticker or hammered paint and it would clear. i believe i have contact somewhere with the front axle as well.
sway bar has no gouging or disfigurement. wear and tear or weight in the rear may shrink the clearance.
may need to keep an eye on that, sway bar could be done away with for my use, but is 800Lbs in the cab going to be too loose? boogie with the whole family?
SPOD
