Thuren 3.0 KING on 2018 Powerwagon!
Re: Thuren 3.0 KING on 2018 Powerwagon!
Post by RustyPW » Fri Jan 04, 2019 4:59 pm
Have questions.
Does Thuren make the 3" to fit the 3G?
Also, do they make the rear with a remote, not a piggyback?
And can you run the rears upside down? I'm think rock clearance. i don't want chit hanging low.
Post by DamageWagon » Fri Jan 04, 2019 5:02 pm
RustyPW wrote:Have questions.
I believe you can custom order the 3” short bodies for only the 03-13 trucks and not 14-present.
You must run the rears shaft-up because the factory brackets barely allow them to fit, you could not bolt the body in that position. If you weld some custom brackets on the frame you could flip the shocks and run hose remote or stick with piggyback.
Post by Colibri » Fri Jan 04, 2019 11:51 pm
I welded in the Carli shock mounts out back and had to cut the bed sheet metal in a couple places to fit my 3,0 bypasses shaft down. It’s not a lot of cutting really, doubt if you could make it happen with stock mounts though
Post by RustyPW » Sat Jan 05, 2019 12:41 am
Pic's?
