Well...this sucks
kgries
Well...this sucks
Post by kgries » Sun May 12, 2019 9:55 am
Has this ever happened to anyone?
Was wondering why my truck seemed a little bouncy...
Rodeoflyer
Re: Well...this sucks
Post by Rodeoflyer » Sun May 12, 2019 10:00 am
Yes it’s happened to others. What shocks are you running (type/length)?
kgries
Post by kgries » Sun May 12, 2019 10:02 am
Rodeoflyer wrote:Yes it’s happened to others. What shocks are you running (type/length)?
They are thuren 3” kings.
I hope I can get a new shock mount welded on
Rodeoflyer
Well...this sucks
Post by Rodeoflyer » Sun May 12, 2019 10:04 am
It can be welded back on. It’s usually an incorrect shock length or the use of shock extenders as the cause.
What stage are your King’s?
kgries
Post by kgries » Sun May 12, 2019 10:13 am
Rodeoflyer wrote:It can be welded back on. It’s usually an incorrect shock length or the use of shock extenders as the cause.
Annoying lol, just what I wanted to spend money on. Fronts are stage 4
Rodeoflyer
Well...this sucks
Post by Rodeoflyer » Sun May 12, 2019 10:15 am
Yeah the 4th gen shock mounts are a notably weak spot. I’m stage 5 front and have beat on mine pretty good for about 70k miles now. I probably need to take a close(er) look at them than I do with my regular underbody and suspension checks.
Post by TankerZak » Sun May 12, 2019 10:20 am
Are you using Thuren springs? His full kit? I'd call Don. That shouldn't happen with his stuff. It's usually from shock extensions..
kgries
Post by kgries » Sun May 12, 2019 10:23 am
Rodeoflyer wrote:Yeah the 4th gen shock mounts are a notably weak spot. I’m stage 5 front and have beat on mine pretty good for about 70k miles now. I probably need to take a close(er) look at them than I do with my regular underbody and suspension checks.
Sad, I only have 14.5k miles on the truck
TankerZak wrote:Are you using Thuren springs? His full kit? I'd call Don. That shouldn't happen with his stuff. It's usually from shock extensions..
Yeah it’s a full kit. I’ll get in touch with him, I doubt it’s the shocks fault though
Rodeoflyer
Post by Rodeoflyer » Sun May 12, 2019 10:30 am
From the looks at the little dirt/oil marks it appears that you’ve fully compressed them a few times. Are you running boogie bump stops?
kgries
Post by kgries » Sun May 12, 2019 10:32 am
Rodeoflyer wrote:From the looks at the little dirt/oil marks it appears that you’ve fully compressed them a few times. Are you running boogie bump stops?
Oh I for sure have, I’ve definitely used the suspension, just didn’t expect a shock mount to fail on the way to work lol. Yes I am
Rodeoflyer
Well...this sucks
Post by Rodeoflyer » Sun May 12, 2019 10:36 am
This area is not welded. Have them weld that part. Not sure why the engineers thought that was smart. This should never occur within the limitations of stock shocks and bumpstops but still...
Post by TankerZak » Sun May 12, 2019 10:58 am
Shock mounts are weak BUT if all the geometry is correct should never break because they should never see downward force. The shock should stop before that. The bumpstop stops the downward force before force is applied to the shock mount. In the up swing the shock mount would see some light extending force as the shock tops out. Either the geometry is off from improper install, improper design, or the shock isn't working correctly for whatever reason. For all of those things I'd call Don. I'm also going to go check my shock mounts as we should have the same setup...
Rodeoflyer
Well...this sucks
Post by Rodeoflyer » Sun May 12, 2019 11:01 am
Absolutely. I’m wondering if the boogies are allowing too much compression. Don’t the kings have some some kind of internal bumpstop? It will be interesting to hear what Don says.
Post by TankerZak » Sun May 12, 2019 11:12 am
Rodeoflyer wrote:Absolutely. I’m wondering if the boogies are allowing too much compression. Don’t the kings have some some kind of internal bumpstop? It will be interesting to hear what Don says.
Yeah, not sure. But I have the boogies too so I shoulda broke a shock mount by now. What springs do you have? The .5 inch or the 1.5 inch PW springs?
Post by Reloaderguy » Sun May 12, 2019 12:06 pm
Damage Wagon burned in my shock mounts when he put on the truss. The factory welds on the shock mounts are terrible and I was uncomfortable with then in stock form. I'm surprised guys didn't rip them off jumping their trucks at PWiM.
Rodeoflyer
Post by Rodeoflyer » Sun May 12, 2019 12:09 pm
Yep, catching air without limit straps probably wouldn’t be a great idea.
Post by Low_Sky » Sun May 12, 2019 1:40 pm
TankerZak wrote:Shock mounts are weak BUT if all the geometry is correct should never break because they should never see downward force. The shock should stop before that. The bumpstop stops the downward force before force is applied to the shock mount. In the up swing the shock mount would see some light extending force as the shock tops out. Either the geometry is off from improper install, improper design, or the shock isn't working correctly for whatever reason. For all of those things I'd call Don. I'm also going to go check my shock mounts as we should have the same setup...
If you think the shock mounts don’t see any force when the shock is stroking, you’re confused about how shocks work.
Rodeoflyer
Well...this sucks
Post by Rodeoflyer » Sun May 12, 2019 1:58 pm
That’s why I was wondering what stage he’s running. My stage 5’s have massive damping. It’s incredibly hard to fully compress them (high speed) short of catching air. The mounts are taking a lot of force.
When I get around to having my axle tubes welded I’ll have them do the shock mounts.
Post by TankerZak » Sun May 12, 2019 2:47 pm
I don't think they see zero force but they shouldn't see shearing force...
Post by DamageWagon » Sun May 12, 2019 5:03 pm
Those shock mounts are seeing a TON of force. Especially with 3.0’s that are capable of putting out twice the force of a 2.5. The factory mounts are *usually* just fine but occasionally there’s an issue like this. Usually from true mechanical bottoming of the shock where the force spikes, but also from the fatigue provided from standard shock damping. Like Reloader said, it was comedy club when we looked at his mounts. They need welding. Even the geometry if they’re welded isn’t great with the design of the mount.
kgries
Post by kgries » Sun May 12, 2019 5:08 pm
Guess I should get the other one fully welded as well then. Hopefully it doesn’t cost too much Image I have other mods I’d like to spend the money on
Rodeoflyer
Well...this sucks
Post by Rodeoflyer » Sun May 12, 2019 5:14 pm
Maybe Don should advertise upgraded lower shock mounts with 4gen 3.0 sales.
Post by DamageWagon » Sun May 12, 2019 5:27 pm
Rodeoflyer wrote:Maybe Don should advertise upgraded lower shock mounts with 4gen 3.0 sales.
There are ‘secret menu’ options that are not sold unless the customer understands just that. Not for the average user.
This is still a special case and is not very common, and I’ve seen as many stock mounts fail from bone stock shocks as from performance shocks so it really comes down to how those mounts were welded rather than how they’re used. Shocks will fatigue the mounts through normal operation. Improper shock length causing bottoming will also add Impulse to the mix which is a whole different issue they causss them to fail fast (read: shock extensions are bad)
kgries
Post by kgries » Mon May 13, 2019 9:10 pm
Got it fixed along with the drivers side as well
Cost me about 110 to get done, wish I had known about that weakness prior, I would have just gotten it done before it broke
Rodeoflyer
Post by Rodeoflyer » Mon May 13, 2019 9:19 pm
Good to hear!
