2020 Ram 2500 Power Wagon spied
Re: 2020 Ram 2500 Power Wagon spied
Post by 04Ram2500Hemi » Wed Jul 11, 2018 8:38 pm
I’m not putting a lot of faith/hope in these spy pictures. They could be testing all sorts of things that will never make the final product. The real hope for me is the 7.0L V-8 that has been rumored to replace the 6.4L Hemi. That could be a good setup in the new Power Wagon and the rest of the HD lineup.
Pit Slave
Post by Pit Slave » Wed Jul 11, 2018 10:48 pm
Still a V8, just without the spark plugs...😉
Pit Slave
Post by Pit Slave » Wed Jul 11, 2018 10:50 pm
Also, what's with the rear doors??
Post by BoldAdventure » Wed Jul 11, 2018 11:36 pm
Just for reference, here's what the 2019's look like. And since Ram uses the same body between the two chassis's we can determine a lot from comparing, even though they are spy shots.
Figure the Rebel is the better comparison.
Pit Slave
Post by Pit Slave » Thu Jul 12, 2018 12:10 am
Show me a standard cab, and we have a sale.
Post by TwinStick » Thu Jul 12, 2018 1:30 am
So much speculation.
Maybe,,,,those lower control arms are actually a kind of I-Beam, that is so HD, they had to lighten them up with the weight saving holes ??? lol :lol:
Honestly, I don't think they could go wrong if it looked like the red 1500 pictured, only sat up higher like PW's do & get the same upgraded interior-only with the PW flair.
For the life of me though, not sure why they don't make a decent front bumper with customer removable (easily removable) air dams.
Chevy actually has the right idea with the ZR2 Colorado. It has only been out a short time & BAMM !!!! http://www.fourwheeler.com/features/171 ... rformance/
Ram could easily do that with the PW. Larger reservoir shocks, a little taller lift, bigger tires, better bumpers, etc.... .
Post by DamageWagon » Thu Jul 12, 2018 2:27 am
If you can put real shocks (3.0+) front and rear, and they improve the traction control system it would be a whole new truck. 7.0L engine sounds sweet but that sounds like some big tradeoffs. Fuel economy isn’t going to go up and I can’t see them putting a less economic engine in place when Ford is killing the market with the EcoBoost
NickTF
Post by NickTF » Thu Jul 12, 2018 8:14 am
I’d personally like to see a badge that says “MDS Lifter Delete”!
Post by coder » Thu Jul 12, 2018 12:57 pm
delete...
AceMan
Site Admin
Site Admin
Post by AceMan » Thu Jul 12, 2018 10:00 pm
Just reading all the speculations, and seeing the pictures, more irons the fact that I think I will probably keep my 2006 and probably purchase something else to tow it that gets a lot better mileage then 7. 5.
Post by TwinStick » Sat Jul 21, 2018 5:53 pm
:rofl: :rofl: :rofl: :rockon:
Post by RustyPW » Sat Jul 21, 2018 9:53 pm
Drove my youngest stepson's '18 2500 diesel with the air bag suspension. The truck is nice. rides nice, handles nice. And power out of the ass. He tows a couple of different trailers. A 5th wheel camper, a goose neck horse trailer, 20ft bass boat trailer, 2 jet ski trailer, and a 14,000 flat bed trailer. With the air bag suspension. There is 4 different settings for trailer weight that you set for each trailer. Press a button and the rear of the truck goes down. Back up to your trailer, hook up and press the button again. The air bags inflate to the preset air pressure.
If I was looking for a new truck. The 3500 diesel with air bag suspension would be at the top of the list.
Mods to the PW; Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper , PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli G2 Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, BIG Pul-Pal, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, Carli Control Arms, Thuren 3" SoftRide Springs, Thuren Rear Shackles, MagnaFlow Muffler, Crown Stainless Brake Lines, MORE STUFF COMIN'.
Post by olyelr » Mon Jul 23, 2018 6:20 am
3500’s still have leaf springs. Don’t offer air suspension for them that I’m aware of.
Post by RustyPW » Mon Jul 23, 2018 3:53 pm
They have air bag suspension. Believe it's a single leaf spring with air bags.
Rear Auto-Level Air Suspension
The Class-Exclusive available rear Auto-Level air suspension ensures level loads no matter the cargo or terrain. With the push of a button, the driver can select from two smart ride height selections, Normal and Alternate Ride Height, for better alignment with a trailer with automatic electronic adjustments to maintain a level load. Contained within the frame-mounted compressor, tank and lines, it's all done in relative silence.
Post by olyelr » Mon Jul 23, 2018 8:43 pm
Gotcha. I knew the air suspension was available for the 2500 (no coils at all), but did not know it made it to the 3500.
As long as the damn things work, they would be sweet for a tow rig.
13powerwagon
Post by 13powerwagon » Wed Jul 25, 2018 8:30 am
2013 tradesman
Thuren 2” coils, track bar and control arms, AEV salta wheels, stock size stt pros, white knuckle sliders, purple cranium dif covers, marathon superhide seat covers.
Post by DamageWagon » Wed Jul 25, 2018 8:54 am
“Reportedly the 2020 Ram HD will be an all new 5th generation truck as opposed to a heavily refreshed 4th generation truck”
This would be very cool and is what I hoped for. Their spy shots show the opposite of this statement - new cab but reusing the existing frame and suspension.
Post by Ducky's Dad » Wed Jul 25, 2018 9:55 am
And the winner and still champeeeen....THE 2005 PW!!!!!
Post by RustyPW » Wed Jul 25, 2018 4:19 pm
:lol:
cb1987
Post by cb1987 » Thu Jul 26, 2018 9:51 pm
i dont see much wrong with the current powertrain but that would be lame if all they do is slap on new sheetmetal
Redman1973
Post by Redman1973 » Mon Jul 30, 2018 3:19 pm
Well... if I had anything to do with the build, it would absolutely come standard with Thuren suspension upgrade (springs, shocks, and shackles), Thuren steering upgrade, Snorkel, Rock Rails, Wattsenegger Front & Rear bumpers, and the iconic ram hood emblem :rockon: :drool: :idea: :idea: :idea:
Power Wagon Registry #47
- Thuren steering upgrade
- Snorkel
"The" Wifes Car
"Liam" 2018 Jeep Cherokee Latitude
My Toy
"VISCO" 2013 196CC Tidewater
Redman1973
Post by Redman1973 » Mon Jul 30, 2018 3:21 pm
:rockon:
- Snorkel
"The" Wifes Car
My Toy
Post by RustyPW » Mon Jul 30, 2018 3:51 pm
:rockon:
Hey Dan, where you been?
Post by TwinStick » Tue Jul 31, 2018 10:52 am
Post by Bill2014 » Tue Jul 31, 2018 11:30 am
https://www.youtube.com/watch?v=RVWKBuYZlWc
Enjoy ! :cash: :cash: :cash: :cash: :cash: :cash: :cash:
It's a long time to wait for the 2022 Rebel!
7.0 liter engine or hellcat engine - either would be acceptable :lockedandloaded:
Locker Bypass
