Torn Bicep Muscle
Re: Torn Bicep Muscle
Post by Ducky's Dad » Wed Aug 30, 2017 12:24 am
Progress!
Post by Colibri » Wed Aug 30, 2017 1:49 pm
Good luck with therapy sir!
Post by RustyPW » Wed Aug 30, 2017 2:50 pm
Rehap starts this Friday.
Mods to the PW; Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper , PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli G2 Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, BIG Pul-Pal, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, Carli Control Arms, Thuren 3" SoftRide Springs, Thuren Rear Shackles, MagnaFlow Muffler, Crown Stainless Brake Lines, MORE STUFF COMIN'.
verdesardog
Post by verdesardog » Wed Aug 30, 2017 5:46 pm
Take all the pain meds as prescribed, better to stay ahead of the curve. Do all of the necessary therapy but don't over do it. You will return to almost normal quick that way! Good luck... :rockon:
Post by FirerescuePW » Thu Aug 31, 2017 10:19 am
Good to hear, Russ
Did the surgeon say the numbness will go away?
Post by RustyPW » Thu Aug 31, 2017 1:58 pm
FirerescuePW wrote:Good to hear, Russ
He said there is a nerve that he had to work around. Under my forearm is the worst. And the brace hits right on that area. :shock: He said that it may go away with time. Not soon enough for me. :(
whitey
Post by whitey » Fri Sep 01, 2017 10:50 pm
For what it's worth, I tore mine 2 years ago. I luckily had one of the best surgeons for that operation in the US. It is now stronger than it originally was. keeping on a strict work out routine helped more than anything else. If you don't work out I think you'll find it won't get back to normal but will be strong enough. The hardest, most painful part for me was wrist twisting excercises which is most of what the bicep does. Actually mentally I freaked out when the cast came off. I've always had huge arms and my arm was bigger when I was in 8th grade. Do all the physical therapy, keep going to the gym after your done with physical therapy and you'll be good. Within a year I was able to do a set of 10 dumbbell curls with 50lbs (one arm). I'm 51 and a lot of guys my age are seeing the same type issues at the gym.
Post by RustyPW » Fri Sep 01, 2017 11:51 pm
Turning a door knob hurts like hell! :lol: First day of rehap. They just want me doing range of motion. No weight lifting for awhile. They had me stretching my arm out and twisting my wrist. They measure my gripping power on both hands. Left hand was 130 lbs, right hand was 105 lbs. when the pain kicked in. I can get my arm out to about 150*, and twist my wrist about 45*. They set my brace so that I have another 10* of motion. I can move it from 90* to 100*, instead of being locked at 90*.
I'm surprise at the number of people who have done this. :shock: Where I work at part time at Home Depot. I'm number 4. My brother, and 3 of my neighbors have done this too. :shock:
Post by TwinStick » Sat Sep 02, 2017 10:04 pm
I thought of all you injured guys today. I was squatting down, working on putting some screen in front of the radiator on the 4Runner. When I was almost done, I squatted down 1 last time & felt like someone stabbed me in the leg with a knife, right behind my knee. Not sure exactly what it was but it about brought tears to my eyes. Could have been a muscle cramp but felt like something snapped/popped. Took an hour before I could walk on it again. Still limping on it. Wife said it could have been because I had pants on, instead of shorts & the pants got bunched up behind my knee ? Getting old sucks, that's for sure. Guy I worked with who is younger than me, is having a hip replacement in Dec ! :jawdrop:
Post by RustyPW » Sat Sep 02, 2017 11:16 pm
TwinStick wrote:I thought of all you injured guys today. I was squatting down, working on putting some screen in front of the radiator on the 4Runner. When I was almost done, I squatted down 1 last time & felt like someone stabbed me in the leg with a knife, right behind my knee. Not sure exactly what it was but it about brought tears to my eyes. Could have been a muscle cramp but felt like something snapped/popped. Took an hour before I could walk on it again. Still limping on it. Wife said it could have been because I had pants on, instead of shorts & the pants got bunched up behind my knee ? Getting old sucks, that's for sure. Guy I worked with who is younger than me, is having a hip replacement in Dec ! :jawdrop:
ACL. Sounds like you might have a small tear. I got tears in both of mine, plus both meniscus.
Post by RustyPW » Mon Sep 04, 2017 9:17 pm
This is how I'm passing my time. Watching videos of me doing trackdays. :lol: Can't do any until next year. :angry: Can't ride the bike either. :angry:
Post by Colibri » Mon Sep 04, 2017 9:22 pm
Hahahaha, I feel for you sir.
Post by RustyPW » Mon Sep 04, 2017 9:57 pm
Colibri wrote:Hahahaha, I feel for you sir.
Thanks! I can't even go shoot a rifle. Think my hunting season is over too. Have reloads that need testing before the season starts. But that ain't going to happen.
Post by RustyPW » Wed Sep 27, 2017 9:55 pm
Making progress. In rehab. I can straighten my arm out. Still have trouble twisting my wrist. But it will twist more now then before. Found out that my wrist had a dislocated bone in rehab. That's why I was having pain in my wrist instead of my elbow when twisting. They popped the bone back in place. Thought I was going to die. :shock: My grip is still the same at 105 lbs. But my left hand jumped up to 135 lbs. :lol: I'm not allowed to pick up any weight yet. Still in the brace, and it's locked at 90deg. I see the surgeon on Friday. Hopefully I can start the weights, and get rid of the brace, or at least allow more motion in it. Enjoying my Comp vacation for the most part. :lol: Learned to do a lot with my left hand. Not back to work yet either. Wife wants me to give it up.
Post by RustyPW » Fri Sep 29, 2017 3:28 pm
Seen the surgeon today. No more brace. Still not allowed to lift anything. Only in rehab for now. Still on comp. I go back on 11/10 to see the surgeon for the last time I think.
Post by Retired BLM Rig » Sun Oct 01, 2017 1:08 am
Sounds like you're making some good progress. Probably not as fast as you would like, but at least it's progress. :cheers:
Post by RustyPW » Sun Oct 01, 2017 12:31 pm
Feels so good to have that brace off. I can sleep better. No more extra pillow. And not worry about hitting the wife with it. :lol: She got clucked twice with it. :o And she doen't happy. :doh:
My arm is about 10deg from being straight out. Door knob twisting is still an issue. Start with the weights on Monday. Tried to pick up a 1 lb sugar bag. Couldn't do it. :roll:
verdesardog
Post by verdesardog » Sun Oct 01, 2017 3:33 pm
Don't get frustrated with seemingly slow progress. It takes time to heal and you will probably never be 100% agian especiallwith your advanced age :lol:
Just imagine if that had happened 100 years ago you would probably never have been able to use that arm agian at all!
Post by Colibri » Sun Oct 01, 2017 4:42 pm
verdesardog wrote:Don't get frustrated with seemingly slow progress. It takes time to heal and you will probably never be 100% agian especiallwith your advanced age :lol:
Children heal rapidly, he might have been okay if it happened 100 years ago :rofl:
Post by Reloaderguy » Sun Oct 01, 2017 7:09 pm
Haha!
Post by RustyPW » Sun Oct 01, 2017 7:33 pm
RustyPW wrote:Feels so good to have that brace off. I can sleep better. No more extra pillow. And not worry about hitting the wife with it. :lol: She got clucked twice with it. :o And she wasn't happy. :doh:
Post by Colibri » Sun Oct 01, 2017 10:12 pm
All kidding aside, I'm really glad to hear you're progressing along rusty!
Post by RustyPW » Sat Dec 02, 2017 7:40 pm
Went back to work today. Light duty until 12/22 with a 10 lbs limit. That's when I go back to the surgeon. Still going twice a week for rehab. Up to 5 lbs curling with 30 reps. Getting some strength back. Still have some issues twisting my wrist.
Post by Mule007 » Mon Dec 04, 2017 10:18 pm
Rusty, sounds like you are progressing well for the most part ! Happy & glad for you, know that is a long recovery. Keep up the good work,,,,
2005 Mineral Gray PW; Alloquin 3" rock rails w/low profile steps; 2.5" Skyjacker suspension lift kit; Toyo Open Country AT II Extreme-35 x 12.5 x 17 10 ply's; McQuay-Norris Extreme ball joints; T-steering upgrade w/Bilstein 5100 steering damper; Bilstein 5100 Mono tube nitrogen gas shocks; Denso 180 amp alternator, Interstate Mega-tron 850 CCA HD battery; MoPar rear wheel well liners, black accent fender flares, remote start, and Ravelco Anti theft device; Hopkins Trailer Mate trailer brake controller; Hemi 1 ton transmission cooler; Uniden Bearcat Pro 68XL CB radio; Linex Platinum black armor truck bed & lower rock panel armor coating; Matching Range Rider cab high fiberglass canopy; 2" Linex (matches Alloquin) round brush guard light bar w/ 4- KC HiLites Rally 400 Series 4" Halogen Driving/off road lights; Dyna-flow cat back dual exhaust; GT Platinum srt-10 A-pillar pod mount programmable performance chip, monitor, tuner; an S&B CAI.
Post by RustyPW » Mon Dec 04, 2017 11:24 pm
Thanks. It's coming long. Not as fast as I like it would. :lol:
