Post
by TwinStick » Sat Mar 11, 2017 1:55 pm
It stops the winch from working if the battery voltage goes below a preset. That feature has left many people stranded, with 70' of cable out. It is a real possibility if you are really stuck & have to really work the winch. The idea is, so you still have juice to start the truck. But realistically, I don't know anyone who would use the winch to unstick themselves without the truck running. Seriously, who would do that, unless the engine was not able to run. Other than that-No one. It would be nice to have something so that you could just flip a switch & bypass.
They also have thermal protection circuit on them. It shuts the winch down if it gets too hot & again, would leave you stranded in the middle of a pull, if it engaged.
I also think anyone who orders a new PW & plans on doing ANY off-roading & does not get the dual alt option, is foolish. Hell, I would get it just for the ease of putting in a high power stereo & not having to upgrade the alternators. Be nice to have a couple 15" subs in the backseat, instead of a single 12" like I do now.
