Ram Rebel TRX Concept
Pit Slave
Re: Ram rebel trx concept
Post by Pit Slave » Thu Sep 29, 2016 11:42 pm
RustyPW wrote:We got 3 threads on this already. A Mod needs to put them all together.
I'm on it....
Re: Ram Rebel TRX Concept
Post by Low_Sky » Fri Sep 30, 2016 12:28 am
The boobs over at The Fast Lane Truck made a 13-minute video and got the Ram reps to give some details. Ram knows they aren't going to build it, and were trying really hard not to give anything for the press to latch onto. They're not calling it Raptor competition. They're not calling it a Hellcat. Cramming the 6.2L and supercharger under the hood required them to cut the firewall back. The front end has longer A-arms (easy enough to put on production trucks), but the rear end is probably significantly different enough from the stock 1500 setup that it won't be feasible for a factory production run.
This is a cool truck to look at, and will probably make some more appearances at media events, but that's the last we'll ever see of it.
https://youtu.be/sfXpzURxCqI
Post by cruz » Fri Sep 30, 2016 4:38 pm
Low_Sky wrote:This is a cool truck to look at, and will probably make some more appearances at media events, but that's the last we'll ever see of it.
X2
These concept vehicles are cool, but they are just a mirage. Remember these two ? ...
Chromolykid
Post by Chromolykid » Fri Sep 30, 2016 6:18 pm
I disagree... I think:
“Furiosa”
2016 Power Wagon
White Knuckle Sliders
DOR Steering Brace
Thuren Stage 1 KING 2.5’s
Thuren Coils Front & Rear
AEV Procal
bdk
Post by bdk » Fri Sep 30, 2016 8:07 pm
X2
I agree most concepts never see production but I think those 2 examples were pretty vast departures from anything currently in production. Also, when those 2 came out the market for single cab trucks was shrinking which also did not help potential sales. I don't think dodge ever really intended for those 2 to see production. However, I don't think they ever really intended to produce the Plymouth Prowler either but with enough excitement I think they would be willing to give even a pretty radical design the green light.
I feel the TRX has a far better chance to see production than a lot of concepts because it is so closely tied to a truck that is already in production. Most of the modifications they made are almost bolt on and with the exception of fitting that engine and redesigning the firewall, it could theoretically be manufactured in the same plant with minimal machining changes. Personally I see them using a power plant that already fits in the engine bay.
Also, the Raptor has proven that there is a market for such a truck. I am not sure there's enough room in the segment for both trucks to sell well, but they would definitely sell some. I think one thing that helped the Raptor is that the MSRP was actually pretty reasonable when compared to a similarly equipped FX4. If Ram could price the STX for around the same price as a loaded 4x4 they would definitely move enough to justify the cost of production and development. Also, the TRX on the lot would get potential customers in the door.
I still agree it's probably unlikely the will build the TRX, I do have a glimmer of hope because of the above mentioned reasons.
bdk
Post by bdk » Fri Sep 30, 2016 8:08 pm
X2
Post by Reloaderguy » Fri Sep 30, 2016 9:57 pm
olyelr wrote:Anybody seen this thing yet?
https://m.youtube.com/watch?v=_m1pEWgFg ... e=youtu.be
It's interesting to watch the diff move around at the 8 second mark and later on in the video.
Post by Reloaderguy » Fri Sep 30, 2016 10:06 pm
bdk wrote:
X2
If you watch some of the videos they show the truck being built chassis up. If you were to build that truck yourself I think it would cost close to $100K. The Raptor doesn't even come close to what they built but that's not to say you couldn't do exactly the same exercise with an F150 and a big pile of cash.
Post by RustyPW » Sat Oct 01, 2016 11:49 pm
This truck is getting alot of press.
http://www.foxnews.com/auto/2016/09/30/ ... money.html
Mods to the PW; Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper , PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli G2 Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, BIG Pul-Pal, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, Carli Control Arms, Thuren 3" SoftRide Springs, Thuren Rear Shackles, MagnaFlow Muffler, Crown Stainless Brake Lines, MORE STUFF COMIN'.
Russ NRA Benefactor Member
Post by RustyPW » Thu Oct 06, 2016 1:19 am
Post by TwinStick » Thu Oct 06, 2016 9:29 am
Is it just me or did someone seriously drop the ball when it came to the front half-shafts ? They look mighty small in dia. I have seen ATV half-shafts that are much bigger in dia & made of CroMo !!! Just sayin'. 575 hp & shafts smaller than an atv ????
LagunaH1
Post by LagunaH1 » Fri Oct 07, 2016 11:53 am
I really really like the way it looks. I wonder if those anemic front half shafts are one of the things "expected" on a concept/ show truck.... given that it likely never will be out of the hands of a factory driver...? Eh, speculative on my part:-)
2016 RAM 2500 Power Wagon SLT
NR6E
Post by TwinStick » Fri Oct 07, 2016 2:57 pm
I like it. I liked the Power Wagon short box concept too, never happened. They would have sold some of them for sure. Hope so. Wonder about the price. I like the hood, the air intake, the super charger, the wheels & the interior.
yellowranger1
Post by yellowranger1 » Tue Oct 11, 2016 10:15 am
yellowranger1 wrote:That's cool, but I can't see legal ever giving harnesses the green light. Hopefully some of the features will trickle down to a production model though!
The Viper ACR has harnesses in it.
Good point! Does anyone know if there's a disclaimer or anything to sign for the acr acknowledging how to use the harnesses? I have 5pt harnesses in my desert truck and it's pure confusion for anyone not already familiar with them. Or maybe this thing would have standard 3pt and the 6pt as an option for off road/mall use.
It'll likely be watered down some if built, bit pretty awesome either way!
Post by 04Ram2500Hemi » Sun Feb 25, 2018 12:05 pm
It looks more and more like Ram may actually build a TRX. Rumor of two motors now: A 7.0L V-8 and of course the 6.2L Hellcat. Why do I think this is important? Because it’s possibly an insite to a new motor for a Power Wagon. My guess is we could see the 7.0L put into a new Power Wagon. Rumors are putting the 7.0L at 550hp and above.
https://5thgenrams.com/exclusive-ram-re ... confirmed/
Post by RustyPW » Sun Feb 25, 2018 4:57 pm
That 7.0 liter would make a great crate motor. I would stick it on my PW.
Post by olyelr » Sun Feb 25, 2018 9:39 pm
Oh c'mon Rusty, you know that old dinosaur couldnt handle that... :lol:
Post by RustyPW » Sun Feb 25, 2018 10:27 pm
I came close to sticking in a motor from the Hemi Shop a few years back. Right after my first wife died. Had the money and no one to answer too. :lol:
Post by olyelr » Sun Feb 25, 2018 11:24 pm
I wanna laugh yet I kinda dont :lol:
Post by RustyPW » Mon Feb 26, 2018 12:19 am
No wife and lots of insurance money. Instead, I redid my parking area and driveway. 50 yards of concrete plus labor. :cash: :cash: :cash:
Post by KevinABQ » Sun Jun 03, 2018 12:03 am
They actually are going to build it!
Ram Rebel TRX confirmed for production
In their financial presentation they point out that Raptors are really expensive and sell like mad, and they want that money. See page 12.
RAPTOR EFFECT
AVERAGE TRANSACTION PRICE IS $71K
$28K ABOVE FORD AVERAGE
2017 SALES 23K (5% MIX)
ATTRACTS YOUNGER BUYERS WITH TWICE
THE MEDIAN INCOME
Post by Low_Sky » Sun Jun 03, 2018 12:46 am
RAPTOR EFFECT
THE MEDIAN INCOME
To sum up that financial presentation; "we're $4k cheaper than market segment average, how can we well these things for more money?"
Post by 04Ram2500Hemi » Sun Jun 03, 2018 10:26 pm
While I look forward to seeing the TRX, I’m more interested in the new HD platform and more importantly the new Power Wagon..
Post by TwinStick » Sun Jun 10, 2018 11:11 pm
x2
Post by RustyPW » Thu Jun 14, 2018 12:07 am
x2
X3
