PWJouster
Post by PWJouster » Mon Jun 25, 2018 3:35 pm
Tda!
17 Method NV-Toyo RT 35
SPOD
PWJouster
Post by PWJouster » Mon Jun 25, 2018 3:39 pm
Leaving sun behind, heading into darkness
SPOD
Post by olyelr » Mon Jun 25, 2018 6:14 pm
You have a bunch of weight in the back of that? Looks like it could use a 1/2” or 1” spacer our back to level it off a little better. And it needs some 37’s now!
PWJouster
Post by PWJouster » Tue Jun 26, 2018 10:23 am
i have two spares!
stock spare under the bed and a fullsize spare with Method wheel in the bed. aftermarket full size will stay bolted down but the stock spare and resonator/ muffler are all being removed! mufflex magnaflow and resonator chop coming soon! (s&B intake, mufflex muffler are also in bed)
should net me over 100Lbs removed from truck once done. most of that bed mounted!
i cant wait to destroy my 35s...trust me.
SPOD
scoutpappa
Post by scoutpappa » Thu Jun 28, 2018 8:01 pm
Making it work for a living. Now it has to drag the base camp as well as make it down the trails. :excited:
xonetruthcrewx
Post by xonetruthcrewx » Mon Jul 02, 2018 3:29 pm
Monache Meadows, CA
Post by TankerZak » Wed Jul 04, 2018 3:39 pm
i have two spares!
I'd look into the Traxada 1 inch spacer. Myself and BoldAdventure run them and i wouldn't do it again without it.
PWJouster
Post by PWJouster » Thu Jul 05, 2018 9:03 am
front or rear? I have Thuren coils front and rear, and will typically cruise without much load. pictures are deceiving as the truck sits very level.
SPOD
Post by Low_Sky » Thu Jul 05, 2018 10:50 am
Rear. A lot of people that opt for the taller Thuren front springs find that the truck ends up a little too level.
BoldAdventure
Post by BoldAdventure » Thu Jul 05, 2018 10:59 am
Front or rear? I have Thuren coils front and rear, and will typically cruise without much load. pictures are deceiving as the truck sits very level.
1-inch in the rear, don't dare put one up front. That being said, I'm always carrying around 250/300lbs of gear. Ram Box's, 37 inches spare, Rack and RTT.
Post by TankerZak » Thu Jul 05, 2018 3:56 pm
Rear for sure. Sorry, i missed a word. I actualy ended up a hair low in the rear on full thuren suspension. I have .5 to .75 of rake with the 1 inch spacer. Just enough to not be nose up.
idtanker
Post by idtanker » Fri Jul 06, 2018 11:39 pm
Boise, Idaho
2013 Power Wagon DG-540199
4.56 Gear ratio, Volant CAI, Mastercraft Courser MXT 35×12.5×17s on $500 American Racing something or others, Pedal Commander, JHD Lighting mirror mod, Grant Stott USB mod, Outlaw Products Zombieflauge Horde canvas seat covers, Onetigris seatback Molle organizers, Heka front mounted 2 inch recievers, Warn epic winch hook, cabin air filter addition with donor cover from another Ram, Wilson cell phone signal booster, modding with AlfaOBD.
Chromolykid
Post by Chromolykid » Mon Jul 09, 2018 6:02 am
Trying out some of the new Thuren parts. This spot used to get at least 1 tire off the ground... Not any more! :cash:
“Furiosa”
2016 Power Wagon
White Knuckle Sliders
DOR Steering Brace
Thuren Stage 1 KING 2.5’s
Thuren Coils Front & Rear
AEV Procal
PWJouster
Post by PWJouster » Mon Jul 09, 2018 9:05 am
looking really good on that flex.
really making me want to remove my rear sway bar.
the constant contact with my rear PC diff cover is driving me nuts.
SPOD
Post by Colibri » Mon Jul 09, 2018 11:37 am
Hot damn! That’s one sexy truck you’ve built. One of the few new trucks that make me think twice about buying a newer truck than my 3rd gen. Did you do the rear diff cover with a stencil or freehand? I love that little touch :rockon:
Chromolykid
Post by Chromolykid » Mon Jul 09, 2018 6:54 pm
Thanks! It’s actually just a sticker, a subtle Mad Max reference since she’s named Furiosa.
“Furiosa”
2016 Power Wagon
DOR Steering Brace
AEV Procal
Post by Colibri » Mon Jul 09, 2018 8:14 pm
I have some chrome spray paint in my glovebox just in case I get to ride my power wagon to Valhalla :lockedandloaded:
Post by olyelr » Mon Jul 09, 2018 10:11 pm
I would check this electrical line and make sure all is well.
Also, it would seem that since this same Thuren setup works with the non-power wagon models you should be able to remove the PW specific bump-stop spacer on the rear for some added compression. Not much, but what the hell.
Looking good!!!! :rockon:
Chromolykid
Post by Chromolykid » Mon Jul 09, 2018 11:09 pm
Good looking out olyelr, I noticed that when I put the track bar on. Just some sheathing that separated. Thanks for the reminder though, I need to wrap it up.
“Furiosa”
2016 Power Wagon
DOR Steering Brace
AEV Procal
Post by olyelr » Tue Jul 10, 2018 4:35 pm
Now that I think about it, I have a loose electrical line in that same area which I think is that same line. There is a connector on it that I could never figure out what it was supposed to get connected to, so my line is just flopping around loose... looks like yours is connected to the parking brake cable. I will give that a try, thanks!
JamesWyatt
Post by JamesWyatt » Sat Jul 14, 2018 1:43 pm
2018 Power Wagon
35x12.5r17 Toyo MTs on AEV RAM Saltas
Post by KevinABQ » Sat Jul 14, 2018 3:58 pm
Looks nice!
Post by TankerZak » Sat Jul 14, 2018 4:07 pm
Nice. Any rubbing at all?
JamesWyatt
Post by JamesWyatt » Sat Jul 14, 2018 6:38 pm
Thanks. No rub at full lock both directions. I haven’t visually checked, but I can’t feel it hitting anything. Haven’t disconnected to check flex, but seems to be a lot of room in there.
BoldAdventure
Post by BoldAdventure » Sun Jul 15, 2018 11:29 am
Wishing I was back. (minus the heat that is there currently)
