RPS1030
Post by RPS1030 » Mon Jan 14, 2019 11:05 pm
TankerZak wrote:
Mon Jan 14, 2019 7:45 pm
Lame driveway pics with new bumper!ImageImageImageImage
Further than my bumper has made it. Started install yesterday. Finished assembly tonight. Still need to deal with the plastics all around and touching up the paint.
Also a nice sunset pic from Saturday.
PWJouster
Post by PWJouster » Tue Jan 15, 2019 10:42 am
Thuren front bumper and Baja/Rigid lights.
Onlyone
Post by Onlyone » Tue Jan 15, 2019 8:56 pm
Low_Sky wrote:
Mon Jan 14, 2019 9:53 pm
Holler at me if you do.
I definitely will. It going to happen. Lol
Same goes for you if you make it down here.
37-12.50-17 KO2s
Post by Retired BLM Rig » Wed Jan 16, 2019 1:58 am
:rockon: Looks like it's time for an update to your avatar. It looks like a completely different truck! :rockon:
PWJouster
Post by PWJouster » Wed Jan 16, 2019 9:10 am
It drives like a different truck!
Kill switch is beyond legendary. you my friend, are a wiz.
wired up the kill switch to the spod! instead of the fuse tap, we have direct power and ground off the Spod system.
anyone who has this kill switch and is thinking about a switch and power system, do it.
the locker bypass install went off without a hitch.
rear worked perfectly, but the front is clicking upon attempted engagement.
the shop had it working on install, but i assume the adjustments were right inline and after putting the truck back together and getting it home, it needs a slight correction.
do you think i have enough wire and loom to place the control module in a more readily accessible place?
Post by Retired BLM Rig » Wed Jan 16, 2019 10:26 am
Not sure. If you find a better location and need a longer harness, let me know and we'll figure it out.
Lazarus
Post by Lazarus » Mon Feb 04, 2019 9:11 pm
:winchmob:
RPS1030
Post by RPS1030 » Fri Feb 22, 2019 8:41 pm
Snow in AZ !?!
Mule
Post by Mule » Sat Feb 23, 2019 2:09 am
Came prepared for snow. Was disappointed. :lol:
PW wouldn't have made it.
shit needed fixin', shit got fix'd. Image
Post by Colibri » Sat Feb 23, 2019 4:03 pm
Mule the Mad scientist on the mountain !
TommyG
Post by TommyG » Sun Feb 24, 2019 5:33 pm
Got this little item knocked out this afternoon.
Mule
Post by Mule » Mon Feb 25, 2019 12:49 pm
Porcupine'd my truck. :doh:
Old 800meg "unicorn horn" in front, to seal the hole for now. GPS puck going on that mount when it comes in.
UHF behind it... EMWave flex. MUCH better performance (SWR's much lower, and I get about 3-5dB better RX to sites vs. the glass-mount).
LTE whip on the back - turns out that antenna is kinda shit. I'll probably replace it with a bullet antenna sometime.
Glass-mount on the back came off last night.
Post by OffroadTreks » Mon Feb 25, 2019 3:28 pm
I need a better LTE antenna myself for the booster.
Mule
Post by Mule » Mon Feb 25, 2019 5:20 pm
https://www.emwaveinc.com/antennas/em-m ... 0-2700-mhz
that's the one i'll probably go with. Lower profile too.
Really disappointed with the Wilson antenna... the mag-mount I had it on previously wasn't the best, and I was able to improve things with some grounding... but I still didn't get traces I was happy with. Replaced the mag-mount with the NMO, terminated it and put it on the analyzer last night... it didn't improve. Haven't really looked at the two traces overlaid yet, but the NMO may have hurt performace a little.
The UHF, on the other hand, is terrific. I'm really impressed with it.
https://www.emwaveinc.com/antennas/emfl ... 20-470-mhz
Post by OffroadTreks » Mon Feb 25, 2019 5:32 pm
Nice, I replaced mine with a Surecall 9 inch awhile ago that seemed pretty good, but it's mag mount. And I want to switch to NMO like my UHF antenna. I had looked at a Larson Pulse too.
Mule
Post by Mule » Thu Feb 28, 2019 1:41 pm
Unicorn-horn replacement arrived - high-performance GPS puck.
Much cleaner now.
Post by Mule007 » Thu Feb 28, 2019 1:45 pm
Looks good!
2005 Mineral Gray; #0666: Laramie, Leather, dual cab control zones, power & heated seats, Alpine 9 speaker surround sound, steering wheel cruise, music & volume controls, 6 CD player, AC; dark charcoal & silver interior.
Additions: Frame mounted .188 DOM 3" steel rock rails low profile steps; 1.5” Skyjacker leveling kit; Bully Dog GT Platinum SRT-10 A-pillar pod mount programmable performance chip, monitor, tuner; Linex Platinum black armor bed & rock panel HD coating; matching Range Rider cab high fiberglass canopy; 2” Linex brush guard light bar w/ 4-KC Rally 400 Series 4” Halogen off road lights; S&B CAI; Flowmaster American Thunder cat back dual exhaust; Remote start; Hopkins Trailer Mate brake controller; Bearcat Pro 68XL CB radio; Mopar black accent fender flares; PW winch kit & remote control;
Tools: 60” Extreme High Lift; hand tools, tow straps, shackles, chains, cables, off road rigging, f&r tire chains, spare water & 2 rear wheel well NATO 20 L narrow gas cans.
Updates: Jasper Reman. Engine; Open Range All Terrain 35 x 12.5 x 17 MP3 10 ply E tires; McQuay-Norris Extreme ball joints (upper & lower); new fuel pump; 1 ton HEMI transmission cooler; new OEM radiator; front & rear drive U-joints; 180 amp alternator, Interstate Mega-tron 850 CCA HD battery; new water pump & serpentine belt; new Bilstein 5100 shocks & steering damper.
Post by olyelr » Thu Feb 28, 2019 9:56 pm
Mule your truck has a serious case of hemorrhoids :lol:
AlaskaTRX
Post by AlaskaTRX » Thu Feb 28, 2019 11:34 pm
What hood deflector is that you’re running? Looks good...
PWJouster
Post by PWJouster » Fri Mar 01, 2019 10:03 am
lund who is AVS style is called aeroskin. its texteured like the new grills/ black bumpers
https://www.lundinternational.com/newpr ... eroskin+ii
Punishher7
Post by Punishher7 » Sun Mar 31, 2019 2:43 am
Post by Will » Sun Mar 31, 2019 8:36 pm
Punishher7 wrote:Image
I use my winch for stuff like that 86% of the time. 13.6% pulling other people out and 0.4% to pull myself out. :)
vie ... =13&t=2333
Punishher7
Post by Punishher7 » Sun Mar 31, 2019 9:43 pm
This weekend was the first time I’ve used mine and I’ve had it just over a year. Kept the trees from taking out the fence and falling in the street. Also pulled three stumps with it as well. Came in handy for sure.
Neuvik
Post by Neuvik » Sun Apr 07, 2019 2:05 pm
Wen't to Joshua Tree last week to do some rock climbing with some buddies. My plan was to cut through Berdoo Canyon Road to Geology Tour road and make a loop through the park but the forest service gated Berdoo Canyon. It was a super bloom down there so tons of flowers n tourists. Not much of em 4x4 so that was good.
Rodeoflyer
Post by Rodeoflyer » Sun Apr 07, 2019 3:29 pm
