Mule
Post by Mule » Sun Sep 16, 2018 9:00 pm
Drove the truck to the grocery store last wednesday. Truck sounded louder than usual. Got home, and sure enough, exhaust had fully separated right after the cats. Poked around under there and figured out what coupler/etc i'd need to do the repair. Need the truck this weekend.
My M18 grinder was still at the tool depot, being repaired under warranty, so I hopped on the moto and ran out to storage to grab my shitty old corded one. Ground down the welds, made some modifications to the coupler to get everything to fit over the parts I couldn't get the grinder to.
Go to put the clamps on thursday night, and one of the clamps is missing the nuts. Truck still inop.
Friday night, stop by Ace and pick up two flange nuts for the clamp. Get 'em on, do a fuel run, and quick run to home depot. Running well.
Going to have my buddy's shop (shop I actually trust) replace the slowly-leaking heater core, investigate why it overheats on a hard pull with a trailer (didn't used to get that warm with the same trailer behind it, so something's up), and while they've got it, i'll have them do a more permanent repair on the exhaust.
Needed the pickup saturday for a tower decommissioning. Like climbing a wet noodle... everything came down fairly easily, but goddamn was it sketchy af over 40ft (of 60ft).
May not be the most fuel-efficient vehicles, but damn they're handy to have. Old junk getting moved around.
Saturday night, finish the prepwork for a bedliner. $80-ish DIY roll-on kit from autozone.
Not super pumped about this stuff (Herculiner). First "primer" coat went on okay, but I feel like i'm going to need a lot more than the 1gal (and additional qt I bought just-in-case) that came with the kit. Like, a lot more.
Waiting on the first coat to cure right now, sun's going down... either finish out the material I have later tonight or tomorrow morning.
I feel like i'll have to buy another kit and throw on one or two more coats before it's sufficiently thick/durable. :angry:
Mule
Post by Mule » Mon Sep 17, 2018 12:29 am
yeah this shit's still tacky. It's waiting till tomorrow morning. :(
Mule
Post by Mule » Sun Sep 23, 2018 6:19 pm
Coat 2 on monday morning. Better, but still not very good.
Mask/prep, apply coat 3 saturday morning.
Coat 4 this morning (sunday), pull masking off this afternoon. Decent, "good enough" quality.
For the time/money i've got into this project, i'd have been better off just taking it to line-x and having them shoot it.
Still needs to sit for a few more days before it's hardened/cured enough to use.
Tailgate and latch cover will get moved into the garage later this evening, truck can stay parked right where it is till next weekend.
Rebuilt the front brake on my moto, actually works right again now. Replaced handlebars and grips while I was at it.
Post by olyelr » Sun Sep 23, 2018 9:42 pm
I know Linex is expensive, but I dont care, it is so heavy duty and looks so damn good.
But kudos for getting that done on your own :cheers:
Mule
Post by Mule » Mon Sep 24, 2018 1:55 am
Local line-x shop quoted me about $400 for it a few years ago.
I've got:
(2) gallon kits, $80/ea
(2) quarts, $30/ea
$220 right there, more than half of their quote just for the materials.
Add in a couple more $$ for tape, xylene, drop cloths, paint trays, etc.
Then factor in two weekends of dicking around with it. :|
If the one $80 kit did a decent job, then I'd say go for it. But it doesn't. Not by a long shot.
For some situations (trailers or small-projects come to mind), the kits might be a decent option. Truck beds, pay someone else to do it right.
trk4sale
Post by trk4sale » Fri Sep 28, 2018 10:36 am
13 years old and still going strong!
I was in the desert this week on a solo trip. It's good to know the Power Wagon will get me there and back.
WTF? IS UP WITH THE SIDEWAYS PICTURES?????
Preview
AEM Brute Force intake
Gibson CAT back exhaust
Super Chips Flashpac Tuner
Wet Okole seat covers
Line-X bed coating
Trac Rac Sliding Lumber Rack
H2 rims
Post by RustyPW » Fri Sep 28, 2018 4:21 pm
Nothing looks better then a 3G. :rockon:
Mods to the PW; Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper , PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli G2 Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, 14,000 lb Pul-Pal, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, Carli Control Arms, Thuren 3" SoftRide Springs, Thuren Rear Shackles, MagnaFlow Muffler, Crown Stainless Brake Lines, Thuren Drag Link, New SmartBar, MORE STUFF COMIN'.
Russ NRA Benefactor Member
Mule
Post by Mule » Thu Oct 11, 2018 4:03 pm
Another epoxy repair job on the feature that holds the reading lamp lens in.
Dumb design; not a lot of support on that part.
Bedliner i'm also not very impressed with. It's had two weeks of no use to set up and harden, which should be more than enough.
Pulled the carbides off my sled for the expo (carbides and track studs will destroy the concrete in the complex, so they have a no-studded-tracks and no-carbides rule for machines on the floor) and had two load/unloads... and the shit's already gouged down to the paint.
I think i'm going to pick up some trailer glides and just turn the bed into a sled hauler. :lol:
Rodeoflyer
Post by Rodeoflyer » Thu Oct 11, 2018 8:33 pm
Man the white paint still shines on your truck. You shouldn't really have to but a deezee heavyweight bed mat would take care of that gouging. I have a drop in liner so loads slide and the HD bed mat provides grip but it's so thick nothing can gouge it.
Lockedup
Post by Lockedup » Fri Oct 12, 2018 4:46 pm
Proud new owner of a 17 PW w/ AEV lift, saltas and 37s
Post by RustyPW » Fri Oct 12, 2018 5:08 pm
I'm at the Outer Banks now until Sunday.
Post by RustyPW » Fri Oct 12, 2018 5:12 pm
Couple more.
Post by Mule007 » Sat Oct 13, 2018 8:15 am
Nice, Enjoy! Looks beautiful.👍
2005 Mineral Gray PW; #0666; frame mounted .188 wall 3" steel rock rails w/low profile steps; 1.5” Skyjacker suspension lift kit; Open Range All Terrain-35 x 12.5 x 17- MP3 10 ply,s; McQuay-Norris Extreme ball joints; T-steering upgrade w/Bilstein 5100 steering damper; updated Bilstein 5100 Mono tube nitrogen gas shocks; new OEM radiator; updated U-joints; Denso 180 amp alternator, Interstate Mega-tron 850 CCA HD battery; MoPar rear wheel well liners, black accent fender flares, remote start, and Ravelco Anti theft device; Hopkins Trailer Mate trailer brake controller; Hemi 1 ton transmission cooler; Uniden Bearcat Pro 68XL CB radio; Linex Platinum black armor truck bed & lower rock panel armor coating; Matching Range Rider cab high fiberglass canopy; 2" Linex brush guard light bar w/ 4- KC HiLites Rally 400 Series 4" Halogen Driving/off road lights; Flowmaster American Thunder cat back dual exhaust; GT Platinum srt-10 A-pillar pod mount programmable performance chip, monitor, tuner; an S&B CAI; 60” Extreme High Lift jack& off road kit, bumper lift & tire lift kit; other rigging
Mule
Post by Mule » Mon Oct 15, 2018 1:57 am
I have a bed mat from my old-old half-ton. Stuff's like 1/2" thick, in two halves. It's like the rubber mat used in gyms. Each half probably weighs 60lbs. :lol:
Should pull it out of my garage closet and throw it in the bed. But again, with carbides on the sled skis that stuff's way too "grabby" and skis don't slide on it. Hence my idea for trailer glides.
Hayman burn area. Couple days of training, camped out for a few nights. 15min commute was kinda nice.
Mule
Post by Mule » Mon Oct 15, 2018 6:18 pm
Post by OffroadTreks » Mon Oct 22, 2018 10:17 am
One of these things is not like the other thing... What could be off here?
Post by olyelr » Mon Oct 22, 2018 10:44 am
What?! Thats obviously one of those unicorn single cab 4th gen wagons... he just put a cummins c on the side to be cool.
Post by OffroadTreks » Wed Oct 24, 2018 10:48 am
Forgot to post some of these. We spent a week in Colorado a few weeks back and had the realization we live in the wrong place.
Ouray/Silverton that area and the trails have got to be my favorite second only to Moab. I has having so much time I barely took any photos. Trails are a lot easier, but the scenery is beautiful and the views amazing.
We're thinking of moving over towards Grand Junction by the Summer.
Ouray & Moab 2 hrs away, yup, I think that's our future.
:cheers:
PWJouster
Post by PWJouster » Wed Oct 24, 2018 2:35 pm
whats the best resource you found for the trails in the CO area?
17 Method NV-Toyo RT 35
SPOD
Post by RustyPW » Wed Oct 24, 2018 5:58 pm
Wifey lived over by Grand Junction. She wants to move back out west one day.
TommyG
Post by TommyG » Thu Oct 25, 2018 7:59 am
The last time we were there we used Trail Damage a lot but I don't know if it is still viable - Traildamage.com
We grabbed this guide and used it a lot too. Well worth the $$$ -
https://amzn.to/2SmxQzy
We are from the East and didn't know anyone out there so we were totally relying on the guides.
lancer29
Post by lancer29 » Fri Oct 26, 2018 12:18 pm
Fresh coat of wax today before the snow flys
2005 Dodge Power Wagon
1977 Ford Bronco
1980 Toyota FJ40
Post by Mule007 » Fri Oct 26, 2018 4:59 pm
Looks good! 👍
Post by OffroadTreks » Fri Oct 26, 2018 6:09 pm
These two books here: https://amzn.to/2CHQlsT & https://amzn.to/2EMamRH
Trail Damage is good, but they limited access. They're an invite only group. Still, there are other things like Dangerous Roads. But the books are real good. We live by the one for Moab. And I use Gaia GPS all the time on the iPad in truck.
Mule
Post by Mule » Mon Oct 29, 2018 11:53 pm
Door hinge. :thppt: Ordered a replacement off amazon.
Hosed it down a few times with the enamel paint from my kitchen sink refinishing kit. Knew I held onto that can for a reason... :roll: Door came off this weekend.
Old bushing was in bad shape. Creaky/squeaky, loose.
Previous owner had done a hack-job repair on the harness/connector. :doh: Works, but it is not pretty nor maintainable.
Door back on and aligned. Spent the next hour chasing down some loose electrical connections. :angry:
But... hinge is smooth now, no squeaks/grinding noises, and it's solid.
