Bush knife
w2dodge
Bush knife
Post by w2dodge » Fri Jan 08, 2016 8:43 pm
Made this knife at home for my p.w. To keep it in the truck with some of my tools...5160 steel I hope..I heat treated as so...she holds an edge so far after chopping that block of hard wood and some cardboard
Re: Bush knife
Post by Colibri » Fri Jan 08, 2016 8:50 pm
Did you make that out of a section of truck leaf spring? That's just about the manliest thing I've ever seen. Where's Tim Allen when you need him? Seriously nice work man!
w2dodge
Re: Bush knife
Post by w2dodge » Fri Jan 08, 2016 8:55 pm
thanks..yep truck spring...alot of work but it was fun....
Re: Bush knife
Post by TwinStick » Sun Jan 10, 2016 11:16 am
THAT is wayyyyy cool !!! :rockon: I am a HUGE knife guy. 5160 ROCKS for a knife blade. It is a steel that can cut other steels, literally !!!
Not 5160 but they used to have a video of 5160 doing the exact same thing.
https://www.youtube.com/watch?v=dB4wLoso-BY
Re: Bush knife
Post by 2wagons1driveway » Sun Jan 10, 2016 1:51 pm
That's effin awsome!!!!
X2 on the manly comment! So cool! I'm guessing extremely time consuming
Sent from Canada
w2dodge
Re: Bush knife
Post by w2dodge » Sun Jan 10, 2016 3:29 pm
thanks guys...twin i watched most of Miller bros videos they make some excellent blades..i cut bunch blanks from a leaf spring from a n.y.c garbage truck..was at the dump at their mechanics shop took apart the leafs from a complete pack they didnt need.. heat treat is important im still learning ...2wagons i took apart a treadmill and took the motor so i can make a 2x72 belt grinder...angle grinder a files take too much time...and bevels dont come out perfect..
Re: Bush knife
Post by adeluca73 » Sun Jan 10, 2016 9:51 pm
Holy shit that's bad to the bone & super creative & talented . I suck. :wtf:
Re: Bush knife
Post by TwinStick » Sun Jan 10, 2016 11:29 pm
These 2 Ontario's I have are made from 5160.
After batoning these through multiple logs with knots, they still easily shaved hair.
vvvvvvvvvvvvvvv
w2dodge
Re: Bush knife
Post by w2dodge » Mon Jan 11, 2016 7:28 pm
Twin those are nice...here's my next project...almost 7/16 inch thick
Re: Bush knife
Post by TwinStick » Sat Jan 23, 2016 10:54 pm
You makin' that for Paul Bunion ??? :lol:
I have an Ontario knife made by Justin Gingrich, It is a Ranger Signature Series, made from 3/8" S7 tool steel. It is my most expensive knife to date @ $150.00, quite a few years ago. Don't let anyone tell you that thick knives can't be shaving sharp either. That one i have literally can curl a single piece of hair.
w2dodge
Re: Bush knife
Post by w2dodge » Sun Jan 24, 2016 9:21 am
TwinStick wrote:You makin' that for Paul Bunion ??? :lol:
Lol. Not yet,I got those pieces so I'm gunna have fun with them,fab some different blades. Chopper,some for the kitchen and then some. We got hit with some snow so I'm going to try to finish up at work if I can. Here's where I'm at with this one
Habor freight. Takes up a lot of time
Full grind. Took some meat off
Need to put an edge 25*
Re: Bush knife
Post by TwinStick » Sun Jan 24, 2016 4:37 pm
Super cool !!! :rockon:
w2dodge
Re: Bush knife
Post by w2dodge » Sat Apr 07, 2018 1:18 pm
finished this blade this wknd....52100..
Mule
Re: Bush knife
Post by Mule » Mon Apr 09, 2018 1:04 pm
Amateurs. :lol:
Re: Bush knife
Post by adeluca73 » Wed Apr 11, 2018 7:28 am
continue to impress man, love it....are you selling these?????
w2dodge
Re: Bush knife
Post by w2dodge » Wed Apr 11, 2018 12:26 pm
Thanks adeluca....maybe when I retire...I need some more equipment...hardness tester...heat treat oven..I'm just using simple steel for now...and testing them...time consuming...
Re: Bush knife
Post by Mule007 » Sat Apr 14, 2018 10:35 am
Nice looking knives!! Good work👍 :rockon:
2005 Mineral Gray PW; Alloquin 3" rock rails w/low profile steps; 2.5" Skyjacker suspension lift kit; Toyo Open Country AT II Extreme-35 x 12.5 x 17 10 ply's; McQuay-Norris Extreme ball joints; T-steering upgrade w/Bilstein 5100 steering damper; Bilstein 5100 Mono tube nitrogen gas shocks; Denso 180 amp alternator, Interstate Mega-tron 850 CCA HD battery; MoPar rear wheel well liners, black accent fender flares, remote start, and Ravelco Anti theft device; Hopkins Trailer Mate trailer brake controller; Hemi 1 ton transmission cooler; Uniden Bearcat Pro 68XL CB radio; Linex Platinum black armor truck bed & lower rock panel armor coating; Matching Range Rider cab high fiberglass canopy; 2" Linex (matches Alloquin) round brush guard light bar w/ 4- KC HiLites Rally 400 Series 4" Halogen Driving/off road lights; Dyna-flow cat back dual exhaust; GT Platinum srt-10 A-pillar pod mount programmable performance chip, monitor, tuner; an S&B CAI.
w2dodge
Re: Bush knife
Post by w2dodge » Sun Apr 15, 2018 7:05 am
thanks
Re: Bush knife
Post by TwinStick » Fri Apr 20, 2018 8:13 am
BEAUTIFUL work.
:idea: You need to make a batch of choppers & etch the "POWER WAGON" logo on it & to get around the "copyright" bullshit, just etch the year of the PW of the people who buy them from you; example: 2008 Power Wagon, for mine. Just a thought, you do great work.
w2dodge
Re: Bush knife
Post by w2dodge » Sat Apr 21, 2018 3:16 pm
Thanks Twin...my first blade I tried to etch a winch hook..it came out so.so....I'd love to make some for us ..just have no time right now...here is couple I'd make over the winter...a replacement blade for my bonecollector and kitchen knife is 52100...and the chopper is o1....
Re: Bush knife
Post by TwinStick » Sun Apr 22, 2018 10:04 am
LOVE me some choppers. I have quite a few. That looks almost like a competition chopper. Latest one I have been eying up is this: https://www.smkw.com/tops-el-chete-knif ... rta-handle .............Awwwww, damn you :lol: ....now i just found another !!! :lol: ........https://www.smkw.com/tops-el-chappo-cleaver
Love me some cleavers too.
:cheers:
w2dodge
Re: Bush knife
Post by w2dodge » Sun Apr 22, 2018 5:11 pm
nice ones...I gotta finish these blades...a lot of grinding
