They have a defect that causes them to release and collapse under load.
According to Harbor Freight's NHTSA filing, the problem with these jack stands is that due to worn tooling at the factory, the pawl that engages with the toothed height-adjustable part of the stand doesn't do so sufficiently to reliably lock it in place. A bump or a knock could cause the pawl to disengage, dropping the vehicle suddenly.
