Popping out of gear
DesertBrewer
Popping out of gear
Post by DesertBrewer » Fri Jan 03, 2020 9:32 am
I recently got my 2019 PW and I currently just have over 1000 miles on it and 3 times in the last week I have noted an interesting failure. It invariably happens when I am parking. When moving the selector from reverse to drive, it pops out of gear (after you can feel that it has switched into gear). There is a slight edging forward and then it stops and the gear selector indicator blinks. I tried cycling between the various selections and back to drive, it typically takes several tries. I have tried turning off the engine and that doesn't clear the issue. The last time I was able to clear it by driving in reverse some (fortunately there was room), and then drive work, but then it locked my rear axle. It's possible I hit that button by mistake, but I doubt it.
I thought I would mention it in case there was some 'feature' I was unaware of.
Thanks for any thoughts.
AceMan
Site Admin
Site Admin
Re: Popping out of gear
Post by AceMan » Fri Jan 03, 2020 4:16 pm
Interesting issue. That's definitely something critical to immediately contact your dealer about, especially for the truck being so new.
Post by Bill2014 » Fri Jan 03, 2020 5:28 pm
The joy of the dial shifter. :doh:
Post by RustyPW » Fri Jan 03, 2020 7:39 pm
2X!
SimonandSimonBeast
Post by SimonandSimonBeast » Mon Jan 06, 2020 9:45 am
Stupid KnobImage
:rockon: :chug:
waldo
Post by waldo » Tue Jan 14, 2020 11:13 pm
Sounds like some kind of glitch in the auto park. You didn't have the door open or ajar by chance, did you?
