2018 Transmission Failure
25k miles on the truck.
said it from the get-go...Transmission tuning is crap, shift logic is crap, lugging is crap, downshifts are crap.
Trans is out for the count.
Had it flushed around 20k miles. At 25k miles now.
The other day it had a hard downshift, almost felt like i got rear ended...
Then the next morning, truck had a harder downshift...this time i had that pit in stomach feeling of being hit, it was so harsh.
The next couple of days, it drove fine, trans temps never above 180 and everything was ok except some hard shifts here and there but not as bad as had happened the prior days.
Then woke up one morning and it sounded like trash, and almost sounded like something was being tossed around the trans pan, but only when in drive and foot on brake. Not in park or neutral.
Then drove it to dodge, had the tech test drive it for 30 minutes.
each and every shift got worse, and upon arriving back at the service isle...temp was 230 DEGREES.What?
I will update everyone shortly. This is trash. I was literally looking at the ATS bypass block a few weeks back. If this is what caused the failure, i wonder if the trans flush set it off? That would be against most logic but you never know.
Re: 2018 Transmission Failure
Isn't the transmission flushed at 100K plus? This is the kind of stuff that scares me on Rams. Mines has done some weird things, but performs normally most of the time.
i didnt have it flushed with a flushing system.FordyceCreekTrail wrote: ↑Wed Oct 02, 2019 10:13 pmIsn't the transmission flushed at 100K plus? This is the kind of stuff that scares me on Rams. Mines has done some weird things, but performs normally most of the time.
oil was drained and refilled.
Why did you flush it? Was you fluid dark/black or was it due to operating characteristics? I get some clunking/hard shifts on mine but I chalk that up to normal with a 8k lb truck on heavy 37s and factory gears.
After reading your initial post I went and checked my trans fluid, level and color looked good.
Transfer case fluid was black, trans fluid color was dark but still translucent, but again, I had hard shifting and bad lugging from day one on stock tires. I had light 35s for most of its life.
I changed the fluids just as a precautionary measure to remove any material floating around from break in.
Is the dealer still gonna look into this free of charge with the 37’s on there? Or did you swap out for stock size tires prior to taking it in?
not to arm chair qauter back the situation but if the trans isnt working right, why keep driving it another 25k miles ? with a heavy foot, 37s and 4.10 gears, i can see the trans burning up. why the tcase oil is black still has me a bit stumped, but it must have seen extreme heat as well
absolutely
Ive been complaining since stock. Which was quickly over. 20k miles on the 35s which are actually 33s.
Still wasnt happy on 35s.
to tell you the truth, and ive mentioned elsewhere, the 37s was an improvement for lugging and shifting patterns. It asked to be in the prior gear more often and it obliged in a completely healthy manor. The 4.10s and 37s is perfect for an 85MPH cruiser.
It just so happened to be that something internally was failing, causing harsher shifts at 25k miles, or something externally was failing(temp bypass valve)(It never ran hot but i never towed,it still could have been staving oil with a bottleneck,or leaking valve body)
we all know a billet valve body, performance Torque Converter, and better tuning this Trans should go 300k Miles untouched.
I wish FCA would at least let me try to upgrade internals, expand cooling capacity, and still warranty the engine, but thats hopeful.
Im sorry, you mean spend $62k on a truck and not use it? With Real Estate being my income and needing a fullsize people carrier?cb1987 wrote: ↑Tue Oct 08, 2019 2:10 amnot to arm chair qauter back the situation but if the trans isnt working right, why keep driving it another 25k miles ? with a heavy foot, 37s and 4.10 gears, i can see the trans burning up. why the tcase oil is black still has me a bit stumped, but it must have seen extreme heat as well
I wont lie, there is wear and tear on this truck. Im in Florida, you ever seen a south Florida Flood? it happens throughout hurricane season and i like to be on top of maintenance still, when no one typically cares.
Thats why im more prone to change oils then most people care for... i planned on keeping the ram for the long haul.
I was in the shop every 5k miles for oil changes, all i ever got from the dealer was if it fails, we will warranty it. Which is perfectly natural for a new vehicle dealer and purchase scenario.
BTW, did not purchase the truck at the dealer its now at if anyone thinks thats different. But ive been doing 1,000s of $$$$ of work with a really great tech i can trust there.
still no call, but i guess you can say im hopeful all will be well.
I have to admit, if my transmission goes out under 250K or so I would likely never buy a Ram again. Its just not normal on a modern truck.
There’s no real way for them to even tell you have an upgraded torque converter or billet valvebody without tearing down your transmission, and why would anyone ever do that in the first place if it’s the engine needing warranty work? A built transmission is really a non issue. If you have an aftermarket pcm, just swap to stock before you take it in.
Didn't you do a tuner a while back? correcting for tire size / shift points / transmission / etc? Definitely don't share that with any dealer...PWJouster wrote: ↑Tue Oct 08, 2019 9:07 amIm sorry, you mean spend $62k on a truck and not use it? With Real Estate being my income and needing a fullsize people carrier?cb1987 wrote: ↑Tue Oct 08, 2019 2:10 amnot to arm chair qauter back the situation but if the trans isnt working right, why keep driving it another 25k miles ? with a heavy foot, 37s and 4.10 gears, i can see the trans burning up. why the tcase oil is black still has me a bit stumped, but it must have seen extreme heat as well
I wonder if something went wrong in that process and hastened your impending transmission failure...
stock gears and 37’s is extremely hard on trans fluid and clutch packs if you drive aggressively, which I think he probably does. Resetting tire size in the pcm doesn’t really change that fact.
always wanted to do a new PCM tune but never got around to it. Diablo was saying they wont sell 2018 PCMs while i had it ordered with Hemifever.
so i canceled it and lived with it.
i have had the AEV procal tool to correct tire size and speedo.
again, 37s just went on 1k or so miles ago.
your going to tell me 37s caused a failure in a month or so of daily driving?
i actually hesitated with the 37s at first when i purchased 35s.
clearly i always wanted to go 37s but i was always concerned about the trans and gearing. so for 20k miles i Dealt with 35s. Clearly, i had no severe trans degradation so i jumped up to the 37s.
i drive the same, but am certainly more cautious about corners and curbs with 37s. Ive been taking it easy by all accounts...
I mean, how hard can i drive post MAS TLIF back surgery that i had in February? ive been recovering for months since that surgery, so its not like i can jump the truck or take corners very fast right now. ( or can i-Thuren/king)
Ive had a sahara and rubicon JKU...and stuck with 33s and 35s respectively...i know the issues with too large of a tire a
PWJouster wrote: ↑Tue Oct 08, 2019 11:27 amagain, 37s just went on 1k or so miles ago.
I was responding to Bill2014 not pointing a finger at you, I should have quoted him to avoid confusion.
No where did I say a month of driving on 37’s killed your transmission, I was clarifying that with 4.10’s and 37’s changing tire size in the pcm does not prevent excess wear and tear on the transmission.
It can be hard to tell a persons tone reading a comment on the internet, but for future reference, I only bother posting here if I feel I can help or add value/information to our little community. I regard this place as an extended family of sorts, I don’t shit on people here.
Most likely, as you’ve said yourself, your transmission problem is due to a combination of the faulty solenoid pack that has been screwing with the newer rams and the actual programming/shift timing itself as well as environmental and use factors. Honestly it’s an issue ram needs to address more seriously.
The RFE series of transmissions are unique in that they were the first or at least one of the firsts to not use sprag/one way clutches to mechanically aid the hydraulic circuit in shifting. That requires exact timing of hydraulic circuits to apply and release in concert and to be able to compensate for clutch wear over the life on the transmission Chrysler had to develop the CVI system. Clutch volume index- how much fluid it takes to compress a clutch pack over a given time to accomplish a shift. This and pwm technology are what allows for the adaptive learning.
The problem, in my opinion aside from the recent faulty solenoid packs is that to optimize comfortable shifts that don’t jar the whole vehicle they have to allow slippage of the applying and releasing clutch packs during overlap. They erred on the side of comfort to attempt to give a sedan like driving experience to owners of 3/4 ton solid front axle trucks. This leads to premature wear and excess heat. Alter the shift parameters and it’s likely to live a long time even under very hard use. Mechanically speaking they’re very robust units.
Sorry for your troubles.
hey man sorry lol trust me when i say, ive valued each of your posts, whether response to me or others.
my response was an obligatory stance rebuttal as when anyone reads it, they will know my thoughts to any comments that may have already been brought up. Reading my post, didnt mean to respond with vengeance.
i just think the lighter 37s and Non Beadlocks that im using, shouldnt even be considered. Everyone does it!
On the other hand to your comments, when i drive alone, which is 80% of the time, im 99% of the time in TOW/HAUL.
Which speeds up shifts, higher RPM, more Force/less slippage?
The trans had a very good shot at shifting like my driving " Style" needed, and it would not have ended this way.
Again, its the MPG tuning that shoots us in the foot. I bet a TCM tune day one and the factory components would probably last.
I wasn't sure whether you, PWJouster, actually ran a tuner or not... (I now know you didn't)
I've used performance tuners on other vehicles with some great success - but that was because I made all the other required mods to enable the extra power. In the case of our 6.4 "truck" engines, the tuners aren't really adding much in the way of power... I brought up the tuner, because the changes to the transmission settings are what you typically feel - not the increased HP at WOT that the tuners deliver. These "special transmission tuning settings" can definitely impact the life of a transmission - look at all the disclaimers associated with the tuners. Fiat is on the hook for our powertrain warranty, so you can be sure that the factory transmission settings are geared more toward longevity than anything else.
Since you didn't use a turner - your transmission woes are likely due to faulty parts or fluid from the git-go. Your trans fluid discoloration is a big concern. I believe everything you have shared but the transfer case fluid discoloration on top of all this suggests there is more to this story...
I wasn't impressed with the 66RFE in my 16. Had the solenoid pack changed twice. Traded it on a 19 with the ZF. Completely different animal.
Surprisingly, the 545RFE in the 07 chugs right along.
2007 and 2019 Power Wagons
so i picked up the truck after 3 weeks and 2 days and it was running just fine about 8 miles home down a main city road, 45MPH. Taking it easy, as if i had just experienced a trans failure...
reverse into my driveway, Hard shift to Reverse, clunk into park.
Thought it was just learning shifts.
10 minutes later, i leave to head to work. I made it about quarter mile with slow acceleration at neighborhood speeds, and once it shifted into 4th, it stayed there....
I noticed the truck felt like it wasnt moving very fast with the pedal application, so i clicked the gear select and it displayed 4th...tried to select 6 and no response. Tried to shift down to 3rd, no response..... pulled over and went into park...shifted to drive, and the truck feels like its lugging, Still displays 4th and shows 4th as the only selectable gear. cant go to 6th and cant go to 1st gear.
With throttle application, i can tell its actually lugging about in 4th...doesnt feel like anything is slipping, just feels like its actually stuck in 4th..
no check engine lights. Restarting did not help.
is this a limp mode?
warranty work showed new bypass valve, torque converter, and other internals and fluids.
$1500 in parts and $1500 in labor.
i hope i get a reman or new unit next, how am i suppose to trust a dealer tech who possibly botched the first fix?
Stuck in 4th is a limp mode. Good luck!
trucks back in my hands.
driving and shifting more solid. Still have Hard downshifts as i always remembered.
Dont remember the trans spending so much time in 3rd though? like it chooses to be in 3rd more often, which does keep me in the power band better.
( im guessing the trans unlearns this behavior by learning how to be more fuel efficient...which is why it gets more sluggish overtime)(this happened when i jumped onto 37s, but is more pronounced now)
feels like its slipping through 1st gear, but is that a "factory fresh reset" condition as it learns my driving habits?
i wish that shit would just lock up for performance sake.... standstill takeoffs feel like im just slipping away from a stop.
upgraded TC would do alot for these trucks, even without a better gear ratio
edit* forgot to say how much i love my Powerwagon...
like wow... it has a behemoth presence, superior capability, and a utilitarian nature.
snorkel and bed rack would set this sheet off.
Happy to hear youre back on the road. I couldn't agree with you more, I do love these power wagons. And call my tacky or an attention whore but I love the 2017+ decals.
Do you have a tuner yet? Being able to adjust the trans is a main perk of tuners. I don’t know if Sheridan makes a valve body for the 66 but that might be an option too. Since you’re paying for the fix it doesn’t sound like much warranty is involved?
I can’t fix the trans issue but I can fix the rack issue
