2016 power wagon axels unlocked but front/rear flashing??
Jriehemann
Post by Jriehemann » Tue Aug 20, 2019 8:40 pm
My axel unlocked light is solid but, my front/rear light is flashing at the same time. Anyone have solution or reason why?
continuecrushing
Re: 2016 power wagon axels unlocked but front/rear flashing??
Post by continuecrushing » Thu Aug 29, 2019 1:28 am
did it just start doing that, or its been doing it since you got it?
I'd check the sensors/magnets. Gotta pull the diff covers off, a great time to swap fluid too.
Post by Retired BLM Rig » Thu Aug 29, 2019 9:29 am
A professional grade scan tool would be able to pull codes out of the Final Drive Control Module and get you pointed in the right direction. Most good repair shops will scan for codes free of charge and then charge for diagnostic time if you want to pursue a solution.
You can also check your 50 pin sway bar and axle connectors for water intrusion, carefully clean them and apply dielectric grease. Bad connections are a common cause of blinking lights.
