After 175k miles I replaced my original 07 ignition coils today with a fresh set of mopar coils and was surprised to see they have been redesigned.
They added a small insert presumably to improve electrical current flow between the coil and the spring to the plugs I personally have not seen this on any other coil. Not a huge deal but kinda cool IMO.
These same coils are used on all Hemi's the 5.7, 6.4 and the 6.2 supercharged Hellcats and Demons.
- 2007 Ignition Coil PN 56029129AB (top)
- New Ignition Coil PN 68238603AA (bottom)
Mopar Ignition Coil Redesign
- NovA ProspekT
Re: Mopar Ignition Coil Redesign
Did you notice a difference after replacing the coils?
Yes, I did actually. I felt a slight bump in throttle response, low end torque and MPG, overall the engine feels smoother. I don't know if it was because I replaced coils with a lot if miles on them (even though there were no codes/issues) or the new coils are better.NovA ProspekT wrote: ↑Sun Mar 17, 2019 10:10 pmDid you notice a difference after replacing the coils?
- Model Year: 2017
Did you replace the plugs or anything else at the same time?coder wrote: ↑Mon Mar 18, 2019 7:41 pmYes, I did actually. I felt a slight bump in throttle response, low end torque and MPG, overall the engine feels smoother. I don't know if it was because I replaced coils with a lot if miles on them (even though there were no codes/issues) or the new coils are better.NovA ProspekT wrote: ↑Sun Mar 17, 2019 10:10 pmDid you notice a difference after replacing the coils?
I changed my plugs about 3-4 months earlier so when I did the coils it was just the coils.
- NovA ProspekT
hmmm...I wonder if the performance increase is from a "better"/newer-design coil or if the old coils were just "worn out"(do they wear out?).
Coils do wear over time they develop increased electrical resistance until the voltage drops below spec or dies and throws an error code. However OEM Hemi coils are known for lasting a long time and being able handle much more than factory HP.NovA ProspekT wrote: ↑Thu Apr 04, 2019 10:34 pmhmmm...I wonder if the performance increase is from a "better"/newer-design coil or if the old coils were just "worn out"(do they wear out?).
