Locker Bypass Rebirth
EpicWagon
Re: Locker Bypass Rebirth
Post by EpicWagon » Sun Dec 16, 2018 6:45 am
I have a '16 Wagon add me please,
Epic Wagon, cash in hand
w2dodge
Post by w2dodge » Sun Dec 16, 2018 12:39 pm
heres pics
Post by olyelr » Sun Dec 16, 2018 3:18 pm
Oh my heavens you must have missed that area when you spraying fluid film this fall.
w2dodge
Post by w2dodge » Sun Dec 16, 2018 9:04 pm
will do..
Longbomber
Post by Longbomber » Sun Dec 16, 2018 11:12 pm
Put me in for one as well. For a 2016.
The best mod to make for the PW, had one of Cajun's kits on my 13. Lockers working like they should is awesome.
FordyceCreekTrail
Post by FordyceCreekTrail » Tue Dec 18, 2018 10:28 am
I will take one for my 18
FordyceCreekTrail
Post by FordyceCreekTrail » Tue Dec 18, 2018 10:32 am
DamageWagon wrote:
Mon Dec 03, 2018 3:39 pm
Detroit Locker.
WTF? Can't believe I missed this :lol: I crossed off a few cities from my will ever visit list after watching parking wars.
Post by Retired BLM Rig » Wed Dec 19, 2018 2:25 am
Previously I said that a disable toggle switch would be mounted on the control box, but that seems pretty inconvenient in a society that caters to convenience. So I'll be offering some options as I build each unit, depending on if you want:
  • A standard unit with no disable switch
  • A generic toggle switch and harness that you can mount in the location of your choice
  • A prewired harness that you can connect to an existing rocker switch panel
  • A prewired harness to connect to a SwitchPros or sPOD module.
This is what the generic toggle switch option looks like.
5' of extra harness with a loop of wire.
Route it to the location of your choice and cut the wire to length.
Strip and crimp the terminals.
Connect to the switch.
The other configurations would be similar.
So if you're on the waiting list, be thinking about what options you're going to want for your custom locker bypass. (No change in price for any of these configurations)
Post by olyelr » Wed Dec 19, 2018 6:31 am
Heck yes, Santy! :rockon:
Post by Low_Sky » Wed Dec 19, 2018 2:48 pm
Retired BLM Rig wrote:The lockers will still be controlled by the factory knob, this is just a disable switch to turn the system off to avoid accidental engagement.
Does the switch disable the dash knob entirely, or just the “bypassiness”?
Post by Retired BLM Rig » Wed Dec 19, 2018 3:21 pm
The green “Axle Unlock” indicator will still be illuminated on the factory knob panel, but turning the knob will have no affect. There will be no flashing lights and the swaybar disconnect will still function according to factory parameters.
FordyceCreekTrail
Post by FordyceCreekTrail » Wed Jan 02, 2019 7:17 pm
Man, already getting tired of the hassles on my 2018. What a bad design. The rear seems to rarely be an issue, but its like pulling teeth for the front now. And when I need to idle up a steep, icy hill to do a recovery I can't drive 2 miles to get it engaged.
Last edited by FordyceCreekTrail on Mon Jan 07, 2019 9:06 am, edited 1 time in total.
Post by olyelr » Wed Jan 02, 2019 7:28 pm
Man, already getting tired of the hassles on my 2018. What a bad design. The rear seems to rarely be an issue, but its like pulling teeth for the front now. And when I need to idle up a steep, icy hill to do a recovery I can drive 2 miles to get it engaged.
Yep, not having much control of the lockers is almost worse than not even having lockers at all.
Jack187
Post by Jack187 » Thu Jan 03, 2019 4:09 am
Please out me on the waiting list. 2015 model. thanks.
jakestopp244
Post by jakestopp244 » Sun Jan 06, 2019 12:28 am
just installed mine today very impressed with the quality and how much better my lockers engage thanks for making these again.
2012 pw
mod list: thuren 3inch coils, adjustable shackles and overland shocks, carli track bar short arms and steering stabilizer, daystar airbag cradles, evo manual sway bar disco, arh long tube headers, diablosport trinity with jay greene 92 octane tune, s&b cai, vision x 4.5 cannons on a pillars, custom plastic cnc switch panel, factor 55 prolink, retired blm's locker bypass
Post by Retired BLM Rig » Sun Jan 06, 2019 3:49 am
That's great Jake! As far as I know, you're the first to install and test one of these.
A couple quick questions:
  • How long did it take you to install?
  • Did it work out of the box, or did you have to adjust the relays?
Post by TankerZak » Sun Jan 06, 2019 11:05 am
I'm a slacker. I got a shit ton of projects, particularly wiring, stacked in a closet. First is bumper and fog light install. Then probably the locker bypass... then switch panel and nanny bypass, lol.
jakestopp244
Post by jakestopp244 » Sun Jan 06, 2019 12:11 pm
i didnt get a chance to install it all at one time but im going to say maybe 2 and a half hours it wasnt long at all and that was with pulling my s&b airbox. but it was defintly helpfull having a lift but not needed. as far as the relays i didnt have to adjust them they locked up as soon as i turned the dial
2012 pw
Post by Retired BLM Rig » Sun Jan 06, 2019 7:36 pm
:rockon:
ramv
Post by ramv » Sun Jan 06, 2019 9:14 pm
Can't wait!
ramv
Post by ramv » Mon Jan 07, 2019 10:08 pm
Got it! I know my weekend plans now
Post by Retired BLM Rig » Tue Jan 08, 2019 2:50 am
For those of you that are still waiting to install your locker bypass, it would probably be best to mount the control box last, so if the relays need to be adjusted, you don't have to go through the hassle of dismounting and remounting the control box.
I test and adjust each unit before it ships out, but sooner or later someone is going to have to make an adjustment. I just want the install to be as hassle-free as possible so it doesn't waist your time. I'll be making a note about this in the future installation instructions.
thedriver21
Post by thedriver21 » Wed Jan 09, 2019 6:27 pm
:excited: 2013 Add me to the list please Retired!!!!!! :excited:
2016 PW Laramie-Flame Red
