xfer case linkage
verdesardog
xfer case linkage
Post by verdesardog » Wed Aug 08, 2018 11:39 pm
I have seen more than one thread about the transfer case shift linkage problems with the rubber grommet so knowing the rubber looses it's elasticity (gets hard) as it ages and my truck is 12 years old I decided to do something about it before it starts to fall off.
Two standard heim joints with 3/8 24 male threads, 4 washers, 2 3/8" nuts, 2 3/8 24 nylock nuts and one rod with 3/8 24 female threads on each end.
It would be best to measure the OEM linkage so that you can get the correct length rod. I got my joints and rod from McMaster Carr and the washers and nuts at Ace.
The holes for the grommets are quite large, luckily both ends are the same. I cut a slice off of a nut to use as a spacer. The one on the transfer case needs to be a bit thinner than the one on the linkage handle.
It is a lot tighter than the rubber mounted linkage and will take a bit of getting used to for smoother shifts.LOL
EasyDoesIt
Re: xfer case linkage
Post by EasyDoesIt » Wed Aug 08, 2018 11:57 pm
Nice work man. Something simple and fewer things to worry about on the trail.
Post by RustyPW » Thu Aug 09, 2018 1:06 am
Nice work. :rockon:
Mods to the PW; Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper , PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli G2 Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, 14,000 lb Pul-Pal, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, Carli Control Arms, Thuren 3" SoftRide Springs, Thuren Rear Shackles, MagnaFlow Muffler, Crown Stainless Brake Lines, Thuren Drag Link, New SmartBar, MORE STUFF COMIN'.
Post by PWJouster » Thu Aug 09, 2018 9:58 am
the stiffer that link, the harsher the input into the shift rod and shift linkage.
how aggressively does your shift lever move now under load and articulation?
the play in that linkage must be there for a reason. although the reliability of your link is substantially beneficial.
17 Method NV-Toyo RT 35
Evo On-Demand Swaybar Disconnect
SPOD
trk4sale
Post by trk4sale » Thu Aug 09, 2018 10:09 am
You will find that a lot more noise and vibration will now be transferred into the cab without the rubber grommets to isolate the metal parts.
I know that at least one person on this forum went back to the grommets because of the noise, but I put up with it because the grommets failed at a bad time for me and I don't want it to happen again.
Preview
AEM Brute Force intake
Gibson CAT back exhaust
Super Chips Flashpac Tuner
Wet Okole seat covers
Line-X bed coating
Trac Rac Sliding Lumber Rack
H2 rims
verdesardog
Post by verdesardog » Thu Aug 09, 2018 10:47 am
Yeah, I haven't driven it yet because of low vision due to cataract surgery. I did think about the noise issue, I guess I'll see soon enough. I'm going in for my new glasses prescription this morning.
Post by Reloaderguy » Thu Aug 09, 2018 11:14 am
I went back to grommets because of the noise but I have a different transfer case with different linkage. If you get noise you can try a rubber dampener on the rod.
verdesardog
Post by verdesardog » Thu Aug 09, 2018 1:48 pm
Took it for a drive today, couldn't hear any difference than before
Post by Low_Sky » Thu Aug 09, 2018 2:06 pm
Guys that have had vibration/noise complaints, what kind of rod ends did you use? The cheap ones without liners, steel ball on steel rod end? Or did you pay up for ball joints with Teflon liners?
Post by Colibri » Thu Aug 09, 2018 3:28 pm
I did Teflon lined rod ends and don’t have any increase in noise or vibration at all
verdesardog
Post by verdesardog » Thu Aug 09, 2018 6:37 pm
The ones I have have pre lubed bronze bearings
trk4sale
Post by trk4sale » Fri Aug 10, 2018 8:53 am
I'm not sure. There was a write-up here a few years ago with the needed parts and part numbers so I just ordered the same stuff from Summit Racing. The noise is not terrible, but I can definitely hear it more than before.
Preview
Line-X bed coating
H2 rims
Post by TwinStick » Tue Sep 04, 2018 10:25 am
Nice work ! :rockon:
IMHO, reliability trumps comfort EVERY time when Murphy comes knocking at your door. :lol:
Traded to 2019 ZR2, Red.
Post by Colibri » Tue Sep 04, 2018 10:30 am
To the guys that have done this and have a noticeable increase in noise and/or vibration, try adjusting the linkage so there’s about 1/8-1/4” free play in it. That’s how I set mine up when I came up with the mod and it hasn’t increased nvh at all on my truck. The trucks newer than 3rd gens I can’t speak to as I understand their linkages are much shorter, but any NV271 truck should be good
