A Tale of Diagnostic Woe
Re: A Tale of Diagnostic Woe
Post by TwinStick » Thu Jul 12, 2018 1:44 am
:rockon: :rockon: :rockon:
:popcorn: :popcorn: :popcorn:
FordyceCreekTrail
Post by FordyceCreekTrail » Mon Sep 24, 2018 12:41 pm
This actually happened to me at a Transmission rebuild shop. They subbed out the rebuild, the guy put in just enough parts to make the truck roll again(minus second gear) and returned the rest of the parts. The shop called the parts places and found out they had been returned for cash.
