Anyone have this style drag link connection and or know how to adjust it to center the steering wheel? I’m assuming you loosen the two clamp bolts the. Twist the sleeve like normal?
Thanks!
2012 drag link adjustment
Re: 2012 drag link adjustment
Yep, loosen the nuts and twist the sleeve.
My build thread. viewtopic.php?f=13&t=2826
Is there a torque value on the nuts or is it a calibrated wrist kind of thing. I see they use nylocks.
About 30 Ft. Lbs. should do the trick.
2008 Quad Cab - Stock RTI = 655, curb weight = 6081 lbs. Abel Components Plug & Play Locker Bypass®, Abel Components Sway Bar Bypass®, Abel Components Nanny Kill Switch®, Trailer Hitch Storage, MOLLE Door Panels, Wilton Hitch Vice, Locking Under Seat Storage Drawer, Smittybilt 2781 Air Compressor, 14K PullPal, Hi-Lift First Responder Jack, 25' Jumper Cable System, Slip Yoke Eliminator in a Can, Evolution vs. God, Share the Umbrella, Make sure you're right with God before you meet him!
