Locker Bypass Rebirth
Buck316
Re: Locker Bypass Rebirth
Post by Buck316 » Mon Apr 15, 2019 1:14 pm
Got my locker bypass last week in the mail cant wait to get it installed! Thx BLM rig!
Sent from my SM-N960W using Tapatalk
IDIOTCARL
Post by IDIOTCARL » Mon Apr 15, 2019 9:33 pm
Hey all,
Wanted to give my feedback on the two systems offered.
First of all these kits are of high quality, are professionally put together, and just top notch as hell.
Start to finish it was a painless process... my turn came up, i paid, i received both the locker bypass and nannie kill system within the week.
Once i got started the kit was fully prepped and ready to go, everything you need.
I did have a couple of questions and i received answers right away..again huge 👍.
Installation was easy and it looks factory. I tested the system and it worked like a charm.
If your on the fence about the system or the cost, GET OFF THE FENCE AND START WHEELING. These set-ups are the bees knees.
Retired blm, you da man!
I find myself using the nannie kill alot when just hopping about on dirt fire roads and the 2wd drive locker option is awesome when pulling a dry hill or a boat at the launch.
Thanks for the awesome system you figured out, R. BLM.
(Side note: on a 2014 at least, the passenger inner fender there is a 1/4 twenty threaded factory stud, it works perfect for mounting the control box for the locker bypass. Its between the firewall and the air box. Takes some riggermaroe to get the box in position, but its a solid, safe spot to mount.)
IDIOTCARL
Post by IDIOTCARL » Mon Apr 15, 2019 10:07 pm
Hey all,
Post by FordyceCreekTrail » Wed Apr 17, 2019 9:11 am
So my sway bar disconnect definitely is not working now. Light might flash a little, go dark, and eventually back to solid connected again. I am assuming this has nothing to do with the locker bi-pass kit install, just the usual flakiness ram has refused to address. I plan to have it checked under warranty on Friday. Just want to be sure there was nothing that could have have been done with the locker bi-pass accidentally to cause this. Not convinced the disconnect really ever worked well....
Post by Retired BLM Rig » Wed Apr 17, 2019 10:02 am
A simple test would be to revert to stock by removing the T-harness and reconnecting the factory axle connectors and see if it functions better. I would recommend doing this anyway before you take it in for warranty work. The sway bar switch wires simply pass straight through the T-harness and are not effected by the bypass. You have to be in 4Hi or 4Lo for the sway bar to work.
Post by PWJouster » Wed Apr 17, 2019 11:17 am
key misstep many will take, because you no longer have to be in a 4 wheel range!
remember that swaybar could use some bypassing as well!
Post by FordyceCreekTrail » Wed Apr 17, 2019 7:07 pm
Does not work in 4x4.
Post by FordyceCreekTrail » Fri Apr 19, 2019 8:55 pm
Just said F it and took it in. Loose connector they said. Was it with Chrysler connectors?
Post by Retired BLM Rig » Sun Apr 21, 2019 3:48 am
Did the shop that you had do the install leave a connector loose? Or was it that way from the assembly line? Did they say which connector it was?
Bigwoody65
Post by Bigwoody65 » Sun Apr 21, 2019 11:21 am
Where do I get this by pass system for my 2011 5.7 Power Wagon. How much?
Post by FordyceCreekTrail » Sun Apr 21, 2019 12:39 pm
They did not give me any info at all. I think it was factory loose however.
astrayer1990
Post by astrayer1990 » Wed Jun 19, 2019 12:53 pm
Retired BLM, I want one of these kits! How do i get in touch with you to get one?! I have a 2018 Power Wagon
astrayer1990
Post by astrayer1990 » Wed Jun 19, 2019 12:56 pm
Retired BLM how do i get one of these kits? it is exactly what i am looking for! i have a 2018 Power Wagon
cb1987
Post by cb1987 » Mon Jul 08, 2019 3:15 pm
finally got time to install the blm bypass yesterday. top notch kit that works great . best thing is you dont have to wait and wonder if or when it will lock. blm system locks right away
Post by olyelr » Mon Jul 08, 2019 7:25 pm
Theres just so much awesomeness in this thread.
Post by Low_Sky » Mon Jul 08, 2019 8:49 pm
cb1987 wrote:finally got time to install the blm bypass yesterday. top notch kit that works great . best thing is you dont have to wait and wonder if or when it will lock. blm system locks right away
Folks who think the lockers lock immediately when bypassed or hard wired don’t understand how our e-lockers work. Not a knock on you, BLM Rig (who is a hero, no doubt), or anyone else. Just pointing out that there’s a big misconception about this.
Bypasses and hard wiring allow the actuator to be energized on demand without the factory constraints. Nothing is locked until the dog ring meshes with the toothed side gear, and the odds are low that those two components will be aligned to allow meshing at any given moment you flip the switch. The majority of the time, they will still need differential action to mesh.
This is one of the reasons I actually like the factory switch(constraints and all). It makes use of the lockers’ sensors and actually tells me when they’re locked. Could I bypass or hardwire them, and just have faith that they’ll lock when I get some wheel spin? Sure. But I like having positive feedback of the locked/unlocked state, and I plan to keep using them as-is until the smart bar craps out.
I think the bypass is great for people that want/need it, but owners should be informed about exactly what it’s doing for them.
m25443
Post by m25443 » Mon Jul 08, 2019 9:02 pm
Low_Sky, You may be right, but..... When stock I rarely was able to get my front lockers to lock without a fair amount of driving in an S pattern or getting the right combination of slip/traction. With BLM's kit, they lock instantly (or close enough that I've never noticed even a 1/4 of wheel rotation before they locked). Say what you will, but they work. And A LOT better than stock. I loved being in Moab and not needing to wonder if my front lockers were going to engage or not.
Post by olyelr » Mon Jul 08, 2019 10:46 pm
Sure, they need differential to lock up... but that can be offered for nearly minutes at times with the factory setup and they still dont lock up... its not just that aspect limiting the factory setup... its just flat out too much electronic bullshit.
Post by PWJouster » Tue Jul 09, 2019 9:53 am
That’s the thing, with the bypass you know the dog gear will mesh as soon as possible, instead of waiting for the ideal moment at which it has perfect clearance at perfect speeds.
Yes you should take care when engaging and slowly roll away with a little turn in the wheel, but it’s locked in just a second. Every single time.
Post by Bill2014 » Tue Jul 09, 2019 2:18 pm
With the locker bypass kit, the physical differential locking takes place as soon as there is alignment for the mechanism to engage - ALL FACTORY SAFETY CONSTRAINTS ARE IGNORED...
It is actually as simple as that.
cb1987
Post by cb1987 » Tue Jul 09, 2019 2:49 pm
im well aware the dogs must be in the right position for it to lock. with the stock setup my front took a while to lock. may of been a time or two that it never would lock. with the blm bypass everything locks right away and theres no tcase position or speed governors. well worth the $450 in my book
jsims006
Post by jsims006 » Thu Jul 25, 2019 12:02 pm
I wonder what safety garbage actually makes locking such a pain. Like what are the conditions and why are they there? I agree you normally wouldnt use lockers until you need them, but by then its too late to engage since you have to be on flat ground, turning in a circle, opening the back door and the hood at the same time, press the left blinker 3 times, etc.
so silly imo
