How to change a A Front Wheel Bearing
Member Builds How-To's
Post by nts007 » Fri Aug 21, 2015 4:15 pm
Hey guys here is a brief write up on how to change your front wheel bearings. Really it is fairly simple but I know some people are still a little unsure how to do it. So here is a brief demonstration.
Tools you need
Basic socket set.
Needle nose pliers
Breaker bar
Long steel spike (or something long and strong but no more than 1 1/4" thick
6-8" 3 jaw puller
1 3/4" socket and ratchet or bar for it
Hammer
New wheel bearing (obviously)
During this process you have the chance to change the ujoint like I did as mine was ceasing up badly.
Also this is a very good time to grease aftermarket ball joints if you have them
Get yourself ready to go. I'm not going to show you how to take the wheel off
Get your stuff ready
Using the same socket that you used to remove your wheel lug nuts, remove the brake caliper carrier bracket. Don't bother taking the caliper off the bracket. Just remove the bracket
Unhook the abs line from the inside fender
A milk crate is the perfect height to store the caliper out of the way
Pull the cotter pin out of the castle nut on the hub then Use the 1 3/4 socket to break the nut free. It will spin off fairly easy once broken. Use a long bar to keep the hub from turning
This stuff works awesome if you need it ever
Next remove these 4 bolts from the backside of the knuckle. These 4 bolts hold the unit bearing on. Don't lose Em. Also don't skip this step and start pulling the bearing. They are 18mm socket
Using the 3jaw pry the hub off the spline. This won't hurt anything. Once it pops the rust it will come off easy
Alright so now you are at this point. Here you can choose to install the new bearing in the reverse order of removal or continue on to the ujoint
In my case out it comes to remove the ujoint
I always bag the splines to keep Em clean. Anything works
This is a good time to grease things so pull out your magic great kit and find the needle grease end. Not the actually needle grease injector just one like this
Re: How to change a A Frong Wheel Bearing
Post by nts007 » Fri Aug 21, 2015 4:22 pm
Continued
Using this little guy grease that pesky lower dynatrac ball joint
There. All greased. Got about 3 shots in it
I replaced the ujoint with a new spicer. This is far more difficult than changing a wheel bearing. Someone else can post how to
Install axle shaft and then slide on new wheel bearing. Now thread all 4 hub bolts and alternating them tighten the hub into the knuckle
Tighten down the hub but and replace cotter pin
And there you go. After reinstalling brake caliper and the abs line. DONT forget the abs line!!
You have finished your wheel bearing. Total time for the change not including the greasing or the ujoint is 1 to 1 1/2 hours. Anyone can do it
verdesardog
Post by verdesardog » Fri Aug 21, 2015 5:16 pm
you did all that work but didn't quite finish it :ugeek:
Post by nts007 » Fri Aug 21, 2015 5:36 pm
No I finished. The unit bearings only cost $330 each. They last 80 to 130k km. sometimes longer.i can't justify the cost of a free spin kit
Re: How to change a A Front Wheel Bearing
Post by TwinStick » Fri Aug 21, 2015 11:44 pm
Wow, just looked em up on rock auto for my truck. Timken HA590166, #5179955AA, $131.79 each. Maybe the diesels are different ???
Good write up. Thanks. This will help people out. :rockon:
Traded to 2019 ZR2, Red.
Post by nts007 » Sat Aug 22, 2015 12:52 am
TwinStick wrote:Wow, just looked em up on rock auto for my truck. Timken HA590166, #5179955AA, $131.79 each. Maybe the diesels are different ???
They are listed here at $600. Rock auto is always cheap but add exchange and shipping and you may save $20 at the end of it. Plus you wait for a week or 2. This is walk in walk out. I'm ok with it. Free spin kit would cost me $3000 at least.
Also I have 09 pw axles. The ones for my original 08 axles were $290 each. For the 05 it's $240. The 09 hub is bigger than the 08
fbenross
Post by fbenross » Sat Aug 22, 2015 2:47 pm
Thanks for the nice write up...I have new Timkens that I haven't installed yet. I paid $140.99 ea. from Rock Auto, but that was 2 years ago.
Chiprat1
Post by Chiprat1 » Fri Aug 28, 2015 12:44 pm
You really need to read and adhere to the torque spec on the Big nut and cotter pin. Just tight will not do it, and you will be back in there again.
2006 Power Wagon
5th Wheel hitch
:winchmob:
Post by nts007 » Fri Aug 28, 2015 1:44 pm
Yes I will. In 80-150k km.
In all truthfulness do you really believe that the dodge techs ever pay attention to torque specs? I know they don't. Only on engine and suspension critical areas. I have many friends that are and have been Chrysler mechanics. On a wheel bearing they just mark the old and realign to the mark when tightening.
In this case the nut is just holding the spline shaft to the hub. The hub is bolted to the knuckle. The spline axle shaft is only connected to the hub and it free floats into the diff. So yes. Tight is tight. Not broke tight but not gonna move tight. The nut just holds the axle shaft in place and is not a support or preload like a Dana 60. It's a unit bearing. Remove the nut and shaft and you can still drive
