Sleeping Platform Build
JPR4LFE
Post by JPR4LFE » Fri May 04, 2018 9:26 pm
This is my take on a sleeping platform for a truck bed. I bought my 2006 Power Wagon in May of 2017, and for the summer ran with a full length platform with an queen sized air mat on top. It worked but based on that configuration I came up with some things I would change.
Design goals:
-Maximize head room. Keep it as low to the wheel wells as possible. Ditch the air mat for a foam mat
-Easily removable. The best feature of the Power Wagon is the versatility. Hauling hay and horses, 4 wheelers, camping, etc.
-Have the ability to use a foot well. Great for sitting up, changing clothes, storing shoes.
-Modular. Full platform for sleeping, partial platform for when pulling the camper.
-Full width of the bed platform
I went back and forth on a drawer, there are some really nice products out there, but keeping it low and having the foot well part of the time and full width other times was a no go. So storage tubs and hatches it is.
https://vimeo.com/267332645
EasyDoesIt
Re: Sleeping Platform Build
Post by EasyDoesIt » Sat May 05, 2018 7:54 pm
Very cool man. Nice work
ghaugo
Post by ghaugo » Sun May 06, 2018 7:35 am
Sweet!
Frame-welded Aluminess Rock Sliders(welded to frame), Cooper STT Pro 315/70/17, ARE Z-Series Topper, FilterMag GP101 (front and rear diffs), DeeZee Tailgate Assist, Skanda Kryptec Typhoon seat covers, Husky X-act Contour Mats, Purple Cranium Diff Covers Front and Rear, Dodge Offroad Steering Brace, K&N air filter, Thuren Track Bar, Thuren Short Arms, Thuren Overland Shocks, Airlifter Ultimate 5000 airbags, Daystar Cradles, High Country Customs Bumper, All AMSOIL fluids from Code4Synthetics.com
Vee
Post by Vee » Sun May 06, 2018 7:53 pm
Nicely done
Post by Retired BLM Rig » Wed May 09, 2018 8:55 am
I'm curious... what kind of storage tubs have you found to fit under your platform?
Also, it's hard to tell in your slideshow pictures but it doesn't look like there's a support leg under the forward cross board, does it flex much or is it secured somehow that I can't see in the picture?
JPR4LFE
Post by JPR4LFE » Wed May 09, 2018 10:09 am
I went to several hardware stores, and the tubs I ended up with are actually hefty brand from Walmart. For a lot of the tubs that I had seen, the lids had an indentation after the lip of the rim, I liked these ones because the lid were raised instead. There is 7.5" clearance a the lowest points, and these tubs were a touch over 7".
You are correct, the forward crossbar (not painted) does not have a center support. It is attached with a bolt and T nut to the side boards at both sides of the truck. You can see some flex at the front most panels at the center, but it is minimal for normal use. I did not notice it when we were using it as a sleeping platform with mattresses installed. I considered adding another support, but I have no plans of doing so at this time.
JPR4LFE
Post by JPR4LFE » Wed May 09, 2018 10:14 am
Some additional pictures
Post by Colibri » Wed May 09, 2018 10:44 am
That is awesome! Good job sir
Post by olyelr » Wed May 09, 2018 11:34 am
Very nice job! :cheers:
Post by TwinStick » Fri May 11, 2018 10:37 am
Well done. Love the fact that you took advantage of all the space to the sides & underneath access. :rockon: :rockon: :rockon:
Post by Reloaderguy » Fri May 11, 2018 11:46 am
That's nice! I used tubs from the local Kroger. they have wheels on one end and pull out super easy. I don't have a center support though.
Post by adeluca73 » Thu Aug 16, 2018 10:34 am
Design goals:
That is most excellent. I like the modular sections and the built-in hand-pulls/hinges on the individual sections.
